Fmonteiro444's Avatar
Car: 09 E92 SG
Default 14' F30 Speedtech 8374 - Going for 700hp - 05-22-2018, 12:00 PM
I received my Speedtech kit last week and the car is in the shop today. Project M is doing the install. I went with the EFR-8374 like luchocamp did in order to try and make the most power possible. This turbo is nothing short of HUGE. I'm excited to get the car back and start tuning.
Default 05-22-2018, 12:18 PM
Awesome!! Can't wait until you get it up and running, I love my EFR 8374 on my N54 as well.
135idct 135idct is offline
Default 05-22-2018, 04:05 PM
is ur car EWG?
KevinC39 KevinC39 is offline
Car: 335i 6MT RWD
Default 05-22-2018, 04:17 PM
I'm jealous. Us E series guys have to cut into the car to fit the bigger turbo. Looking forward to hearing how you like it.
Car: 09 E92 SG
Default 05-22-2018, 04:40 PM
Originally Posted by 135idct
is ur car EWG?
Yes sir.
Default 05-22-2018, 04:42 PM
Originally Posted by Fmonteiro444
Yes sir.
Will be interesting to see how that works, will you be moving the electronic actuator over to the EFR?
Default 05-22-2018, 06:00 PM
i run this kit from aug, 2017, my car is EWG
easy to control boost.
Car: 09 E92 SG
Default 05-23-2018, 09:28 AM
I believe so. Pretty sure you need to do that.
Good to know, thanks.
Default 05-23-2018, 11:02 AM
Awesome! Is that what you had to do? Remove the EWG from the stock turbo to the new one?
VACust's Avatar
VACust VACust is offline
Car: N55 2012 335i M-Sport Coupe
Default 05-23-2018, 12:09 PM
Yes. EWG use the factory BMW actuator and rod instead of the BW one. I'm pretty sure PWG does to, and I'm about to find out. I bought a TurboSmart EFR dual port bypass valve and waste gate actuator to see if I could get them to work on my PWG car. We will see in a few weeks if it works out.
2012 E92 335i
SpeedTech Stg3 EFR-8374, Wedge/MHD, BMS CAI OCC & CP, PSP 900 IC, HKS Legamax, PR N55 Coils, Fuel-It Bucketless Stg3, TTFS +60 HPFP, EOS manifold, Fuel-It lines and E-Sensor
1998 E36 M3 Sedan
Car: 335i 6MT RWD
Default 05-23-2018, 12:41 PM
VACust, how hard was it to get the 8374 to fit on the E92?
VACust's Avatar
Default 05-23-2018, 12:52 PM
My kit gets here Friday. I had to fly to Minneapolis for work and Jeff was nice enough to take me for a ride and let me see how close everything is on his car. I honestly think a little work with a dead blow will give it enough room. If not I'll notch it and reinforce. I had to clearance the same area on my E36 and I thought it really wasn't that bad to do. I'm pulling the sub-frame while I do the install to put in other parts at the same time and give myself a little extra room to modify anything needed.
2012 E92 335i
1998 E36 M3 Sedan
Default 05-24-2018, 06:12 AM
yes, that's it, control boost same as the stock turbo
Default 05-24-2018, 10:06 AM
Super easy!
luchocamp's Avatar
Default 05-24-2018, 01:43 PM
great kit
15 BMW M4 Full Weoght 10.69@133mph stock turbos SOLD
18 BMW XXXX Car in Process
Car: 09 E92 SG
Default 05-28-2018, 11:38 AM
Originally Posted by luchocamp
great kit
Thanks for your help. The shop figured out the water pump fitment issue!
luchocamp's Avatar
Default 05-28-2018, 12:48 PM
Keep it up
Car: 09 E92 SG
Default 05-30-2018, 11:23 AM
So they finished the turbo install. Car cranks but won't start with the JB4 installed. Throws charge air pressure and wastegate codes. But it fires right up if he uninstalls the JB4. Thoughts?
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 05-30-2018, 12:16 PM
maybe they mixed up TMAP/MAP sensor, other stuff you cannot mix up anyway. even without obd2, FF and wastegate I don't think it should matter you are idling only..
N55 - Doc race 6266.
Default 05-30-2018, 12:46 PM
No idea to be honest, just saw your order. Getting it out right now for you.
Car: 09 E92 SG
Default 05-30-2018, 01:21 PM
Board is fried.
Default 05-30-2018, 03:15 PM
Woah, never seen that before!
Car: 09 E92 SG
Default 06-01-2018, 11:26 AM
With the JB4 unplugged, but harness still installed, can I drive the car home at least? Would it just run off flash settings? JB4 was set to Map 7 prior to melting.
Default 06-01-2018, 11:51 AM
No you'd need to pull the Jb4 harness out for it to work.
Car: 09 E92 SG
Default 06-01-2018, 11:57 AM
I don't need boost. I just want to turn in the rental car and drive mine home.
