Tsmith42 Tsmith42 is offline
Car: 2014 BMW 550i
Default 2014 n63tu help - 08-23-2020, 11:49 PM
Having issues with the wastegate when my jb4 is installed. It’s giving me a drivetrain error is there a way to completely reset the jb4 settings to stock to see if changing something messed with it?
Default 08-24-2020, 05:28 PM
Post up a JB4 log of the issue if you need tuning advice.
Car: 2014 BMW 550i
Default logs - 08-25-2020, 01:01 PM
these are the logs map 0, map 4, map 1. im also getting a drivetrain error when i turn on the accessory before i even start the car.
Default 08-26-2020, 12:37 PM
Looks like it's stuck in limp mode. Photo of BCM connector install and actual codes via JB4 app?
Car: 2014 BMW 550i
Default Ok - 08-26-2020, 02:22 PM
The bcm connections aren’t installed the codes are 121542 and 120908 and the code for the maf being disconnected
