Bee Pee Bee Pee is offline
Car: BMW F20 m135i
Default Forced Induction Interchiller - 12-12-2018, 02:58 AM
Anyone had any experience with a universal kit onto B58 from these guys?
In short a system that taps into oem AC circuit to cool charge cooler water ***** - interesting/novel or bonkers ??
https://fiinterchillers.com/project/...-interchiller/
BP
F20 M135i EB AT with options - what a hoot !
f9kandy f9kandy is offline
Car: M140i
Default 12-12-2018, 03:10 AM
It would be great for 1/4m cars that sit in a queue heating up.
Not sure there is much to be gained if mainly used on the open road/track, a Meth kit would likely be better option for that.
Peter @ Pure's Avatar
Car: F20 M135i
Default 12-12-2018, 06:48 AM
We have that installed on our M3. Works great!
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Default 12-12-2018, 09:19 AM
Interesting, never heard of doing that but it's a good idea. Data on it?
Default 12-12-2018, 11:49 AM
GTR guys do it actually IIRC.
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 12-12-2018, 03:08 PM
Some lambo guys with twin turbo kits use this to supplement the heat exchangers so they can use smaller cores for better stealth fitment. I heard it puts a huge strain on the ac compressor though and causes it to fail faster than normal. Plus all of the parasitic loss you get with the AC running and sometimes the car runs weird on idle.
Mods: Stock for now
RMM RMM is offline
Car: 120i
Default 12-12-2018, 08:53 PM
wait a minute, the AC unit heat exchanger transfers heat form the refrigerant to the low temp inter-cooler water circuit
I found this out when you lose your low temp coolant first thing that happens is your AC stops working.
So when you use your AC your heating up your inter cooler low temp water
I do not think this works unless you also put the hot side of the AC heat exchanger to a separate radiator, does the kit also include that?
Or your just taking the heat out then dumping it back + losses, which end up in actually heating the water up?
Nugs Nugs is offline
Car: 2011 135i
Default 12-12-2018, 11:02 PM
From their site
HX BYPASS VALVE
In 99.99% of installs the customer is looking for all out drag racing, street racing and daily driving performance, so the front mount heat exchanger is deleted and replaced with the chiller and a reservoir. However should you wish to circuit race your car you may wish to retain your factory heat exchanger. For this we can supply a 4 port bypass valve which will give you ON/OFF control of when you use your heat exchanger. In most cases we recommend you simply delete the heat exchanger and donít bother with the bypass valve. The reason for deleting the heat exchanger is simple, the intercooler fluid is so freezing cold that the front heat exchanger is no longer a cooling aid, it will actually heat up the intercooler fluid.
Car: F20 M135i
Default 12-13-2018, 01:52 PM
Yeah we have ran a few events with the kit this year and won a few events with the kit too :D while everybody was heatsoaking we were running sub ambient temps :D
peter@pureturbos.eu
pureturbos.eu
Car: 2011 135i
Default 12-13-2018, 05:43 PM
Did you retain the factory heat exchanger?
Your car looks like a beast.
Default 12-13-2018, 06:17 PM
Steve, we need to get this on your M4!
Default 12-13-2018, 06:31 PM
Sweet...Peter are you a dealer? If so, get us the info and we'll install one on the M4.
Car: 2011 135i
Default 12-14-2018, 01:14 AM
It's an Aussie company, it's popular on supercharged commodores here which is why I brought up the idea of putting one on a B58. Didn't realise it had been done to a S55 but very cool to see.
Car: F20 M135i
Default 12-15-2018, 12:18 PM
We resell these as well. I have sent you a mail. We also plan on putting one on b58.
peter@pureturbos.eu
pureturbos.eu
Default 12-17-2018, 12:36 PM
Thanks...we'll continue via email and get this installed.
