(#26)
TTM5 TTM5 is offline
Car: M5
Default 07-13-2021, 04:27 PM
Engine is like new GTI and turbo remained the same as 248/252hp version. On 91 around 310hp and on 93 around 315hp or so on the 252hp version so the ouput should be more on yours.
U mentioned it uses the same turbo and the 12v does not add hp just spool, so wouldnt the power be the same as the 2020?
Default 07-13-2021, 04:54 PM
In theory yes, in practice no. We will know more once its run.
2021 VW Golf 8 R
Car: M5
Default 07-15-2021, 11:27 AM
Does the 2021 q5 w/tune run 30psi psi of boost like the gti?
Car: M5
Default 07-18-2021, 03:34 PM
AFter or on this weekend.
Where is the dyno sheet george?
Default 07-18-2021, 04:25 PM
Will post more information early in the week. Power at the wheels. Boost targets are similar to 248/252hp version.
2021 VW Golf 8 R
Car: M5
Default 07-18-2021, 05:24 PM
A stock a4 makes 261whp?
Default 07-18-2021, 05:48 PM
Yes, was coldest run. Seems its under rated.
2021 VW Golf 8 R
Car: M5
Default 07-18-2021, 05:57 PM
How much whp does a 2020 make?
Default 07-19-2021, 05:15 AM
I have seen 250 to 260whp. We havent had one on our dyno.
2021 VW Golf 8 R
Car: M5
Default 07-19-2021, 10:42 AM
George, jb hardly seems worth it for a 20hp gain on map2....
Default 07-19-2021, 11:48 AM
Mapping is different on this, map 3 will be used for 93/94.
2021 VW Golf 8 R
Car: M5
Default 07-19-2021, 08:34 PM
Ok but even map3 30hp gain is not much, was expecting at least 50hp on 94 ....
Car: M5
Lightbulb 07-21-2021, 04:29 PM
330hp or so. Looking more into things it looks like the 262hp motor is closer to a Gen4 motor than a Gen3.
Looks like nowhere close to 330hp on 93/94, right?
Default 07-23-2021, 04:49 PM
Thats more or less where it is if you factor correction from wheels to engine. If you factor in 15% losses it will be around 345hp or so keeping in mind the car is underated stock.
2021 VW Golf 8 R
Car: M5
Default Yesterday, 03:33 PM
What bhp does a 2020 q5 make vs 2021 @345hp on 93/94?
