Car: 2007 335i Coupe
Cold Idle Exhaust Miss (Video-with BMW Performance Exhaust) -
05-19-2013, 01:35 PM
Hi guys,
I bought my E92 with 44k miles. The car has always done this at cold start-up. It has a miss or skip that is audible. Even my wife asked me about it! "What's wrong with your car?" It's much easier to hear in person than when recorded on an iPhone. The car may do it all the time at warm idle too but I just can't hear it, probably because it's quieter when warmed up.
In the video the miss begins at about .42 seconds and continues irregularly.
Otherwise the car runs smooth and strong. No codes show. No CEL on.
Coil? I think it's ignition related but I don't know what's causing it?
http://www.youtube.com/watch?v=JxQ15cAKLTg
Space Gray, 6MT, Sport and Premium Pkg., JB4 G5 ISO, VRSF 7" FMIC, BMW Performance Exhaust, BMS DCI - OCC - CDV - and Clutch Stop, M3 Spoiler, Clear Bra, 20% Tint
Car: E90 LCI M-Sport
05-19-2013, 04:29 PM
In for the answer. Mine does the same thing. No cel, no other running issues so its not a concern really.
135i is in my sights...
Car: 2011 WRX STI
05-20-2013, 12:20 PM
Mine also does this and even more since i got the new injector model installed. Brought it to the dealer and they said its perfectly normal and they cant do anything about it. No CEL, codes, etc. The tech (who i trust) says it doesn't even register as a single misfire according to the scanner they use. Once the oil is warmer (>100*f) it doesnt happen at all.
Car: 335i CDV
05-20-2013, 06:33 PM
n54 DI is doing that naturally. There's no problem. Now, I did change my plugs to NGK cloer gapped than the factory, and idle became much smoother. I think they are just numbers of small misfires maybe, and closer gapped plugs seemed to fix that.
 Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
05-21-2013, 05:09 AM
Okay. Well, those responses atleast make me feel a little better that other N54s do the same thing. So maybe I don't have to diagnose further. :-)
Anyone else have the misfire sound at cold idle start-up?
Car: 07 335 coupe
05-21-2013, 05:16 AM
mines will only on e85 mix too high..  for less than a minute
Car: 535xi Wagon
05-21-2013, 12:53 PM
Mine did this at 48k miles. Took it into the dealer and insisted (over the course of 5 days) them inspect the injectors and fuel pump. They replaced all 6 injectors and ran a boroscope through the intake to find a fair (not terrible) amount of build up on the intake valves.
The injector replacement alone did not fix the hiccup. 2 weekends later I cleaned the intake valves and got rid of the idle hiccup. Mine was doing it both cold and warmed up. Every 15-30 seconds the exhaust would miss and "puff" a little. It was easy to spot on cold mornings by watching the steady stream of exhaust condensation/smoke get disrupted by the miss.
I could feel the miss/hiccup most obviously in the shifter and clutch. My wife was able to feel it in the passenger seat too.
long story short. Clean your intake valves.
Car: 335i CDV
05-21-2013, 01:37 PM
How did you clean yours?
Believe me, my closer gapped ngk plugs helped me dramatically!
 Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
Car: 535xi Wagon
05-21-2013, 02:07 PM
I am a n54 newbie but I am mechnically inclined (I've replaced head gaskets, done timing belts and clutches on different cars). This was a 5 hour project for me. I removed the intake manifold, rotated the engine to make sure the valves were closed, filled the ports with carb cleaner and used a set of brushes (harbor freight "pipe cleaner" wire brushes), picks and a shop vac. Bolted it all back together and went on my merry way
Car: 335i CDV
05-21-2013, 04:20 PM
I wish I had a time to do.all that. Great for u.
 Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
Because Racecar
Car: '08 135i
05-22-2013, 07:15 AM
My 135 was doing something similar months ago. Spark plug change helped a bit, but what really fixed it and smoothed it out was cleaning the intake valves/ports.
-'09 135i MT - Custom 6466 ST - 680whp
-'08 135i AT - 6466 ST - dead
-'97 318is - Daily
-'82 320i
05-22-2013, 09:34 PM
I ran a bottle of techron through my tank and WOW, it made a difference in cold startup misfires. 5 months later however, it is starting to come back.
I guess it is time for some more.
Turbo PWC performance www.macsboost.com
08xi, jb4 Iso, meth with 2.5gal trunk mount reservoir, CPE *********, alpina trans flash, MACSBOOST IC. Occ catch can, External C&R oil cooler, macsboost rear suspension rod end adapters. H&R sport springs, koni fsd. 12.25@ 113.21mph @ ZMAX dragway.
05-24-2013, 09:27 AM
Regarding the Techron - it's been a year for me so I'll have to put some in.
Well, from reading the responses.....maybe the presence (or absence) of the cold idle exhaust misfire/hiccup is somewhat of an indication of the need for intake valve cleaning....
It would be nice to discover that this type of audible signal from the engine is informing us of sludge on the intake valves. Mine has 57k miles on it and I was trying to wait until 75k to clean 'em based on what I've read.
If anyone plans on doing an intake valve cleaning in the near future please record your cold idle before the cleaning for comparison and then post it.
05-27-2013, 04:42 AM
My intake valves were cleaned(apparently anyway) at 39k, same misfire at cold start...nothing has really changed in the last 12k. My plugs have about 6k on them....maybe it's time to check the dishonest dealers work..
Guy with the pet snails
Car: 135i vert
09-26-2016, 05:24 PM
My car has done this since it was new. Its just normal N54 idle I guess
Motorsport Photographer, PM for Pricing on Car Shoots - mattkalish.com
Car: 2009 135
09-29-2016, 07:35 PM
My n54 does the same even with intake valves cleaned, New plugs, newer injectors. It doesn't seems as bad before ******* dp was installed tho. Which makes me suspect the cold idle tune from factory was tuned with the restriction with te cats, now that I m ******* causing the tune to not run as smooth. Also remember the o2 don't work until they warm up. So on cold start car is running on base map
Car: '08 535xi
10-01-2016, 08:04 AM
I bought my 08 535xi with 85,000 miles with the same issue... More prevalent with colder temperature. Replaced spark plugs, coils, vanos solenoids with each upgrade offering some sort of benefit, just not correcting the cold idle.
Recently, walnut blasted the intake valves and all cold idle stumble and miss is gone. It's been a week of <60 degree mornings and nothing but smooth running.
Some pics of the process at https://goo.gl/photos/7B7am2uyjCQf6E9g8
'08 535xi -- BMS JB4, DCI, OCC
Indianapolis area
Car: 2008 335i convertible
10-01-2016, 03:36 PM
It doesnt take a lot of gunk to affect the valve train, Especially when cold.
I had 40,000 miles on my car when I bought it & it needed a walnut blast period!
Any upgrades from stock magnifies any minor issues. If you do a lot of city driving that is considered severe duty. And maintenance needs to be done sooner. You want it to run smooth, just accept the fact that these cars are high maintenance & expensive if you can not DIY.
And fuel additives will do nothing for the valve gunk because the car is direct injection, & the fuel is injected after the valves.
2008 BMW 335i Convertible
ADE Bottom Mount 6062 Single
VRSF Charge Pipe & 7in intercooler Tial BOV,
Ign Project Plasma Coils & grounds
Robs High & low side Catch Cans with
head plugs.
Diff Brace, Fuel it stage 2 & Meth Port Injection
Aquamist HSF-4 Meth injection
Alpina Flash
BMW PE Mufflers
MDH Flash
Line lock & 16in Drag Radials
11.7 ET, 1.8 60ft, 122mph
Thread Tools |
Display Modes |
