Car: 07 335i
New to the forum.... seeking advice on misfire/injector/hpfp issue. -
04-27-2019, 06:20 PM
A little background on the situation...
Picked up a 2007 335i sedan about 4 months ago w/ 106k on the clock for $700 bucks. Spun rod bearing, bent rod and disintegrated piston #5 cylinder. Other than that it's in pretty damn good shape. I don't know it's history in detail other than the p/o ran it fairly hard (jb4, down*****, cai... not sure what else).
Fast forward to present... new to me engine installed w/ 102k out of a 2007 335i convertible. So far mods include VRSF 2" stock location silicone inlets, BMS DCI, JB4 on map 2 and a dual oil cooler w/ factory t-stat flipped for continuous circulation setup I put together. Engine has index 1 injectors across the board. I'm assuming original coils and unsure on the mileage on the spark plugs. I've got some NGK 95770 ordered and should be in hand tomorrow.
So, I need some advise from you guys that have more knowledge than myself.
I'm currently getting codes:
-2E35 injection valve cylinder 6
-29D2 misfirings cylinder 6
-29D0 misfirings cylinder 4
-29CC misfirings several cylinders
To get to the point... I know injectors, coils and plugs can and will cause these codes but can the hpfp be a culprit for taking out injectors? My fuel pressure reads up to 17 on JB4 logs. I thought normal pressure at WOT was in the 10 -12 range...? I'm sure I've missed important details to aid in y'alls input as far as diagnosing goes so let me know what else will help and I'll let y'all know. Thank you in advance for any input on this!
Car: 07 E90 335i
04-28-2019, 09:59 AM
Post a proper log
Also when was the last time you did walnut blast?
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Car: 2007 335i FBO stock turbos
04-28-2019, 10:13 AM
I would go on a limb and say injector #6 is your culprit, at least one of the problems. That code 2e35 is very straight-fwd; it’s normally bad injector or bad connection to the injector. 29D0 could be a result of a bad coil/spark plug/ bad connection to coil, vacuum leak etc. other two codes resulted from these two.
1/4mile 11.8@117.96 19psi
07 E92 335i (the Alpträum) | Alpine wht/ Seibon carbon hood/ trunk| M parallel wheels| street tires
FBO| modified oem airbox lid w/K&N drop-in| stock turbos/ stock inlets| Walbro 465lph LPFP| Jb4/mhd backend flash| Map 6 w/E60 No Meth| Built and tuned by me.
Car: 07 335i
04-29-2019, 02:23 AM
Originally Posted by Haynpunch
Post a proper log
Honestly I haven't had a chance to pull a proper log. I have some random ones from JB4 doing what I assume is auto logging. A proper log is first on the to-do list as soon as I get this injector swapped out, assuming that's the culprit. I have an index 10 out of the original engine I'm going to install. The intake runners and valves are clean, I walnut blasted it while it was on the engine stand before dropping it in the car. Thanks for the reply! I've got a lot to learn and I appreciate any feedback.
Car: 07 335i
04-29-2019, 02:36 AM
That's more or less what I was thinking. I'm going to swap in a different injector and go from there. I guess I was worried my DME might have some issues.... one thing at a time... I know. Any thoughts on my fuel pressure reading 17? I'll upload the couple logs I have even though they're not correct 3rd gear 2k to redline pulls. I realize it's pointless until I give you guys some actual numbers logged to view. Hey... thanks for the input! Very much appreciated.
04-29-2019, 09:16 AM
That is a bit high to be honest but I would get the other issues sorted before I worry too much about that reading. A stuck injector could affect your pressure reading, Another common issue is the fuel pressure sensor.
Car: 07 335i
05-04-2019, 09:52 PM
Ok... swapped out cylinder 6 index 1 injector for an index 10 and input new injector values with INPA. Also installed new NGK plugs (one step colder than stock) and all is well for now.
ManiN54... question for you.... in your opinion what's the best way to correct the lean condition due to ctls **'s? The old plugs are showing a lean condition (tan in color/no oil) and I've yet to find a definitive answer on how to correct the o2 sensor readings. No mil light but when I read codes with jb4 it always comes back with a "ctls ** detected" code.
05-05-2019, 05:01 PM
Can you post a log please?
05-05-2019, 07:40 PM
Tan in color does not determine a lean condition, if it is tan in color and otherwise clean - no carbon buildup, it is normal. As for the codes you are getting; you will not avoid that if you are ********* unless you have the proper backend flash. Note that these setting are designed for off-road/track only vehicles.
As Dave requested; post up some logs and you can be further guided in the right direction.
Food for thought; always go for index 11 or 12 when buying new injectors. Also make sure your plugs are gapped correctly. 0.022” in your case.
Car: 07 335i
Log review -
07-14-2019, 02:08 PM
Running E33 @ 95-97 octane (don't have a test kit yet so the octane rating is a guestimation assuming the E85 was 100-105 octane).
5 gallons E85 / 11 gallons 93 octane.
Car: 07 335i
07-14-2019, 02:09 PM
Planning on doing the pump BEF tonight.
07-15-2019, 07:28 AM
Load the pump flash- it’ll help big time with the trims
Keep an eye on your LPFP, try and stay around e30 or so for now
Car: 07 335i
07-15-2019, 09:24 AM
Will do.. . Thanks for the reply!
07-15-2019, 12:24 PM
throw up a log when done
