LincolnMateo LincolnMateo is offline
Car: BMW
Default brake booster vacuum hose replacement - 06-05-2021, 08:51 AM
I was cleaning out my intake valves the other day and accidentally cracked the old brittle hardline the previous owner installed as a replacement for the brake booster vacuum hose after installing relocated inlets. I noticed afterward that my brakes are very hard to press and hardly work. now and I am looking to replace the line.
https://snaptube.cam/ 9apps
Does anyone have any recommendations on what type and size of hose to use? I would prefer to be able to buy a hose at some place like AutoZone or napa.
Thanks for any help!
Tecitez16's Avatar
Tecitez16 Tecitez16 is offline
Car: 2009 335i
Default 06-05-2021, 09:16 PM
https://www.realoem.com/ everything you'll need plus some will be here.
kd7iwp kd7iwp is offline
Car: 2009 535xi wagon manual transmission
Default 06-08-2021, 08:36 AM
I personally think you'll have to get the correct hose. Any generic, non-formed lines will just collapse under the vacuum (my guess) where they are bent, and/or they will kink. Had to replace the vacuum line to the booster on my E46 and there was no way I could do it with generic hoses since there were all these crazy bends. Plus it was a lot larger hose than the standard 4-5mm stuff (which those can bend fine since they're so small).
cindyburnette1 cindyburnette1 is offline
Car: BMW x5
Default 06-22-2021, 03:21 AM
Try using only OEM components.You should find the part number for your car on etkbmw.com and use only original details.
