joshquintana's Avatar
joshquintana joshquintana is offline
Car: F30 335i
Default First JB4 + BEF F30 N55 PWG LOGS, Please take a look - 08-22-2018, 08:52 PM
Hello this week I decided to move from MHD stage 2+ to JB4 + BMS BEF, these are my first logs. Did some pulls on map5 and then map2.
My car is an F30 N55 PWG 2013 with the following mods:
- VRSF Charge pipe
- VRSF *** less **
- Evolution Racewerks FMIC
- NGK 95770 spark plugs gapped to 0.020
- CTS Turbo Intake
- Running latest ISO Firmware on JB4 11_T3
- Running latest BEF map from 8/2/18
Used crappy pump fuel (the only one available in my country like 89 oct or less) + Torco octane booster (used 1 can for 5 gallons of gas)
Did this test with octane booster to determine if I should expect good results by adding a meth kit, also to decide if I should use 100% meth, or 80/20 WMI mix
Here are my JB4 settings:
What do you guys think about my logs? and what advice could you give me for next steps with meth
Car: F30 335i
Default 08-24-2018, 08:44 PM
Any feedback?
Car: F30 335i
Default 08-30-2018, 02:50 PM
can someone help me a bit here? thinking twice about buying the bms meth kit if i wont get any support
Default 08-30-2018, 03:36 PM
Sorry, the forum guys must have missed this. I moved it to the right forum for you. If that happens in the future you can always email in too.
We can see the JB4 settings in the CSV log at the top. I see you need more duty bias. Set FF to 100, relog map2 for me.
Thanks,
T
Car: F30 335i
Default 08-30-2018, 07:51 PM
Thanks Terry, I'll change that value and log again
