(#6101)
alexSU's Avatar
alexSU alexSU is offline
Car: Infiniti Q50
Default 10-11-2021, 09:17 AM
hey everyone. would you mind checking my map 1 log?
also what the easiest way to save and post logs from iphone?
2019 q50 silver sport
93 octane
no mods
waiting to install fuel lines
Alpha50's Avatar
Alpha50 Alpha50 is offline
Car: 2017 AWD Q50
Default 10-12-2021, 02:06 PM
I have a good map 6 for E30 mix only, live in CA so E30 for the win. Both 8 and 9 psi. 9 being the limit. Will most likely take some mods to run efficiently. (Well with in the Stillen report) Will post after dyno pulls. FYI I am AWD, RWD will most likely have massive wheel spin. Lol ��
alexSU's Avatar
Car: Infiniti Q50
Default 10-13-2021, 07:31 AM
JCB i know you already replied to this in the other thread but i wanted more visibility and see if anyone else has a comment about the log.
Terry or anyone else? any thoughts on this map 5 run?
2019 Q50 Silver Sport
JB4
Alpha50's Avatar
Car: 2017 AWD Q50
Default 10-13-2021, 09:05 AM
Looks good to me but clearly I donít work for BMS. Lol
alexSU's Avatar
Car: Infiniti Q50
Default 10-13-2021, 09:42 AM
haha any and all feedback is appreciated. the trims look a little high so i just did a log on map 4.
JB4
Default 10-13-2021, 10:07 AM
Get the fuel wires installed. Trims are maxed out and AFR's go lean at tip in but not affecting AFRs mid run and up top as those could stand to be a little leaner anyway. Otherwise the log looks normal.
alexSU's Avatar
Car: Infiniti Q50
Default 10-13-2021, 10:21 AM
thanks steve! once thats done i'll log another run.
JB4
31Jeffe 31Jeffe is offline
Car: 2019 INFINITI Q60 Luxe
Default New JB4 Owner - 10-16-2021, 06:48 PM
Please take a look and let me know if everything looks ok.
Just installed my JB4 and did a log of 4 pulls on Map 3 using 91 gas with a 16oz can of Royal Purple Maxx Octane to bump it to 93+. First pull I didn't shift... LOL I was more concerned with getting the log started. Next 3 I got a couple shifts each. Let me know if this is clean data and enough to determine if everything is ok.
FWIW- I love the performance already. Just want to make sure I won't break anything.
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 10-17-2021, 07:08 AM
Looks like the car is pulling timing. Fuel additive is not doing it for you. Can you get true 93 octane? If not, many have had success mixing in a bit of E85 to raise the octane. Generally the octane boost out of a bottle is frowned upon and looks like its not doing the job for you anyway. Many believe the additives can foul plugs and other components.
For now I would back down the boost to map 1 until you can clear that tank of gas and try again.
Default 10-18-2021, 12:36 AM
Thanks for that. Im in Vegas and we only have 91 or 100. I will blow through this tank and try again with some E25 mixture to get the octane bump. I'll post when I have a fresh tank. Thanks for the help.
Darren Lewis Darren Lewis is offline
Car: 18 Q50 RS
Default 10-19-2021, 08:03 AM
Anyone from BMS able to take a look at how flat/low the timing is here? Does this look ok?
Default 10-19-2021, 12:29 PM
Please upload the CSV file for review.
Car: 18 Q50 RS
Default 10-19-2021, 12:32 PM
Sure thing, here you go.
Some more info...2018 RS, 93 octane, map 6 + FW (3k +1, 3.5k +3, 4k +4, 4.5k +3, 5k +2.5, 5.5k +2.5, 6k +1.5, 6.5k +1)
Default 10-19-2021, 07:22 PM
OK reloaded with 4 gal of E85 and 16 gal of 91. The math says that's E25. I did 4 pulls. The last was kind of weak, I ran out of road.
First Pull was on Map 0 just for a baseline.
Second Pull was on Map 2 Again for baseline.
Third and Fourth were on Map 3 to see if I can run it on this mixture.
Couple questions, I realized as I was pulling back into the garage that I had the ETC on for all of these. Does the traction control ruin the pulls for assessment?
Can you run E30 full time without a Flex Fuel Kit being necessary?
alexSU's Avatar
Car: Infiniti Q50
Default 10-20-2021, 09:09 AM
finally got fuel wires installed and did a map 2 log.
let me know how it looks, thanks again guys!
JB4
Alpha50's Avatar
Car: 2017 AWD Q50
Default 10-20-2021, 10:57 AM
I’ve been running E30 mix for some time. It is the maximum your stock fuel system can handle. Long term use may claim your hpfp do to maxing fuel trims ie you high pressure fuel pump. Also there is no way to know your E count in tank with out 1st testing the ethanol content you are receiving from the pump. example: the station down the street here has 90% E85, some test at 80 or as low as 75 I’ve seen.
SilentQ SilentQ is offline
Car: 2018 Q50S
Default 10-20-2021, 09:07 PM
What did you do to have only these parameters show, very cool!!
Car: 18 Q50 RS
Default 10-21-2021, 07:48 AM
Are you referring to the log I posted?
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 10-21-2021, 07:57 AM
The Map 0 log looked great except for one anomaly - at time stamp 37 the timing goes to 0.5 from 11 in the previous time stamp. It immediately goes back to looking great. Have not seen that before so hope that is just a fluke.
Map 2 log - Timing looks great to me. Concern is that fuel trim is maxed for much of the pull. In 3rd gear AFR looked a little lean. Later in the pull, AFR richened to what is normal to see without fuel wires.
Map 3 log - Timing looks good. Trims are not maxed as much as the map 2. The AFR is still a little lean in 3rd gear but it catches up to "normal" faster than the map 2 pull.
2nd Map 3 pull - looks great except for another timing anomaly at timestamp 638.75. Ign1 value dropped from 15 all the way down to 5.5. Usually a big sudden drop like that would indicate a knock event. The 15 seemed high to me though and 5.5 is not necessarily a bad number to see in the middle of a pull. Its just the sudden change in the value that is throwing me. The timing recovered quickly to 9.5 and looked normal to me the rest of the pull. Trims were high again but maxed less and AFR looks improved further.
I don't know what to recommend to you at this point. My novice advice would be to back down the E content slightly to help with the trims/AFR. Hope someone from BMS looks at this and can tell you if you should be concerned about the couple of timing anomalies.
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 10-21-2021, 08:22 AM
Timing looks good on all the pulls. On the map 5 pulls your trims are maxed for much of the pull and AFR is slightly on the lean side. Maybe back down to map 4 and see if trims/AFR looks better.
alexSU's Avatar
Car: Infiniti Q50
Default 10-21-2021, 11:20 AM
map 5? i did a few map 5 pulls but they werent showing up on the app. where do you see that? sorry i know thats a dumb question but where i normally see my logs on the app it showed 1 for map 2
JB4
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 10-21-2021, 11:37 AM
I open the csv file in excel so the entire log is easy to review. You switched to Map 5 at time stamp 198.25.
alexSU's Avatar
Car: Infiniti Q50
Default 10-21-2021, 11:39 AM
wow im an idiot LOL. thanks JCB.
map 2 and 3 feel really good! i'll try a map 4 log soon as well. those fuel wires...i wasnt expecting a difference but was pleasantly surprised.
JB4
JCB JCB is offline
Car: 2018 Q50 3.0t
Default 10-21-2021, 12:36 PM
You are new to this and just learning the app and how to read the logs. I was in the same place a year or so ago. Hell I even asked what settings would give me the best gas mileage on here. Users at the time politely told me that I was in the wrong place if that was my concern!
Car: 2018 Q50S
Default 10-21-2021, 09:54 PM
Yes, that chart
