Q50S_JH Q50S_JH is offline
Car: 2018 Q50S
Default UPDATE +EWG Wires/MAP 5 - (LOG Review - Map6/JB4 - 2018 Q50S) - 09-23-2020, 09:32 AM
Hello! Attached is my log, please review. Would like to try Map 5 during this cool weather.
I had to shut it down before I got through 4th gear completely (I assume that's the 1:1 gear ratio?)
Map: Map6 +6 with slight taper on each end.
Fuel: 93 octane ethanol free (with 2.5 gallons E100)
Thanks,
Jerry
Default 09-23-2020, 11:20 AM
Log seems OK to me but if you don't mind a little more install work I suspect the EWG connections would be useful here to improve boost and response.
Car: 2018 Q50S
Default 09-23-2020, 11:30 AM
Excellent, thank you for the quick response!
Should I move ahead with trying map 5, or will there be no gains without the EWG wires? I didn't really want to install those (for quick uninstall purposes).
Car: 2018 Q50S
Default Added EWG Wires - 10-07-2020, 10:09 AM
Ok, I added the EWG wires. That was very simple, thanks! Attached is the new LOG for your review, using:
-MAP 5
-Initial EWG settings per the first page of EWG install
Default 10-07-2020, 02:47 PM
Looks good to me here, feel improved response with the EWG wires?
Car: 2018 Q50S
Default 10-07-2020, 03:50 PM
Yes, it definitely felt like it snaps quicker after each shift and pulls harder at the high end!
Do you see empirical data here that shows a better response compared to before? I could not tell at quick glance. I assume the boost is closer to target? Is the +7 from map 5 the most I can go at this point? My 93/e100 mix seems to be a good combo.
Jer
