G70 2.0T G70 2.0T is offline
Car: Genesis G70 2.0T
Default 2.0T spark plugs for JB4 - 08-04-2020, 10:19 AM
Hi everyone. I have a Genesis G70 2.0T and I'm going to be installing a JB4 soon. Have any of you regapped the factory spark plugs for the 2.0T or are you all running the HKS M45XL? If you are using the factory plugs, what gap?
Thanks for your help!
jason.brys10 jason.brys10 is offline
Car: 2016 Kia Optima 2.0T
Default 08-04-2020, 10:22 AM
I am also curious about this for the optima 2.0t engine.
Iam Broke Iam Broke is offline
Car: 20 Veloster N pp
Default 08-05-2020, 07:21 AM
I ran map 2 on stock plugs but changed to hks plugs and map 5 with 30% ethanol currently. Velo N pp 2.0t
Default 08-05-2020, 02:21 PM
Thanks for the info. Were you running the stock gap on your stock plugs or did you close the gap down? Did you send in any logs to BMS to see if everything was running properly with the stock plugs?
Default 08-05-2020, 02:23 PM
I had the stock gaps and no issues but didn't have the logs reviewed for map 2. All was fine on 93 octane here.
Default 08-06-2020, 10:32 AM
Sounds good. Thanks again for responding.
If any of the BMS guys read this (Terry?, Payam?, Ando?) can you please weigh in on stock plugs and plug gap for the 2.0T (G70 in my case.) I only have access to 91 octane fuel and was only going to run Map 1 or Map 2.
Default 08-08-2020, 10:56 AM
Question for the BMS guys: If I want to try the stock plugs with the JB4 on my G70 2.0T (on Map 1), would it help at all to close the gap down (easy to do on the four cylinder) or should I just try it as is?
Default 08-08-2020, 12:33 PM
I'd run a log and see how it looks. If it looks like it could benefit from closing the gap down, do it, but if it looks okay, no point.
Default 08-08-2020, 08:00 PM
Ok thanks. I'll give it a try.
1st timer's Avatar
1st timer 1st timer is offline
Car: 2015 Kia Optima turbo
Default 08-09-2020, 04:35 AM
I tried the. M45xl plugs but found them them to be too cold and they carbon fouled easily and was getting rough starts. Switched to M40xl wich is 1 step colder than stock Gapped at .028 and they seem to be alot better. Manufacturer suggested gap for the 2.0T is .028"-.032"
2015 Kia Optima SX-T
Mods: ultimate racing strut bar, JB4 set at map3, HKS
M40XL plugs, cpe bellmouth, injen intake ,Forge BOV, catch can. Continental extreme contact DWS tires
Default 08-09-2020, 07:39 PM
Good information, thank you. For my Genesis G70 2.0T the factory plugs are listed in the service manual as SILZKR8H9G with a gap of .031-.035 inches.
For the 3.3T with a JB4, BMS says regapping the factory plugs works just fine. But for the 2.0T, that option isn't listed and only the M45XLs are recommended (gapped .022-.026.) Looks like it will cost me about $120 to get four of those.
Since I'm only going to be running the lower maps, I'll try as Dave suggested with the factory plugs as is, send in some logs, and see how it goes.
