Installed new injectors, getting a bunch of codes now -
04-29-2020, 06:53 AM
So I've got a 2008 335i and replaced bank 2 Index 7 injectors with Index 12 along with OFHG and serpentine belt. Used Pro Tools to code them and double and triple checked the numbers. Now when I go to start the car I get these codes:
29D0: Misfire cylinder 4
29D1: Misfire cylinder 5
29D2: Misfire cylinder 6
2E1C: Firing, Cylinder 5
Shadow Codes:
2FCA: Fuel high pressure
2FDA: Crankshaft sensor, signal missing
When I started the car it did take a couple seconds for it to start and then had a rough idle. The car has never had an issue starting up before. All parts were purchased through FCPEuro. I'm on MHD Stage 2+ with MSD80 if that's any help. Any thoughts on why I'm misfiring and suddenly it's taking longer to crank?
