PhilTrill's Avatar
PhilTrill PhilTrill is offline
Car: 135', E46 M3, E36 M3, S13
Default Why isnt my WGDC maxed out? Pushing factory turbos to the limit - 03-15-2020, 06:46 PM
Targeting 24psi, I spike to 24-26psi but then taper from there. I understand stock turbos probably cant flow that to redline but shouldn't the WGDC be maxed the entire time, keeping the wastegates shut? Any opinions and input is appreciated, thanks!
(attached logs)
'08 SGM 135i | '12 C63 AMG | '95 S14 | '93 S13 | '90 S13 | '89 S13 | '80 Spitfire
Rustl3r's Avatar
Rustl3r Rustl3r is offline
Car: 135i N54
Default 03-16-2020, 03:23 PM
WGDC won't max out because the turbo exhaust wheel would overheat and melt.
Also, you may think a turbo failure is a write-off but a broken compressor will send metal into your engine, destroying it. Proceed with caution.
'08 BSM 135i N54B30A 6AT: 133k miles
Dynamic Autowerks Stage 2+ Hybrid Turbos
JB4 + Pump_USA BEF
VRSF 3" Pippys
VRSF Relocated Hotside Intake
Vargas High Flow Outlets
VRSF 7" FMIC
VRSF J Pipe and Charge Pipe
HKS BOV
Black Market Racing 3.5" Exhaust
BMS OCC & PCV (Boost side only)
N20 MAP Sensor
Eldor Coils
NGK 97506 @ .0020
255R 235F Pilot Super Sports on Breyton GTS-R Wheels
Motul Sport 5W40
E30 Fuel
Default 03-16-2020, 11:16 PM
I’ve seen healthy stock Turbos w. Inlets meet that psi down low / mid range & then trail off towards redline. If the Turbos are healthy they can take abuse, but may not last.
The stock Turbos are so small and generate a lot of torque downlow- Blowing the Turbos is 1 concern, however id actually be more concerned with possibly bending a rod from all the downlow torque
