Car: 2008 e92 335i
My DAW Stage 2+ data logs -
01-21-2020, 11:41 AM
I just installed stage 2+ DAW with upgrade compressor wheel, they have less than 200 miles on them. I am running MHD hybrid turbo BEF and map 2 on jb4. I plan on getting a custom flash after I know everything is good. Two of the pulls were at 50 meth injection and one was at 100. The turbos spool up really fast, car feels good.
My mods,
Jb4 w/MHD hybrid BEF, e60 fuel
Meth injection at CP, running 49/51 boost juice
FBO
Upgrade inlets and outlet
3.5 inch VRSF catback exhaust
N20 plugs and eldor coils
N20 3.5 bar TMAP sensor
Stage 2 lpfp
01-21-2020, 12:46 PM
Your HPFP is tanking pretty hard..
What are you using for fuel?
Car: 2008 e92 335i
01-21-2020, 01:06 PM
I’m using e50/60 blend, I have a stage 2 lpfp and meth injection at CP
Car: 135i N54
01-21-2020, 01:33 PM
Also, it looks like you are slightly overshooting on boost and you haven't adjusted the duty bias for hybrid turbos. I've got the same hybrids as you and had to do that to keep the boost curve smooth. your boost safety should also be higher around 22.
'08 BSM 135i N54B30A 6AT: 133k miles
Dynamic Autowerks Stage 2+ Hybrid Turbos
JB4 + Pump_USA BEF
VRSF 3" Pippys
VRSF Relocated Hotside Intake
Vargas High Flow Outlets
VRSF 7" FMIC
VRSF J Pipe and Charge Pipe
HKS BOV
Black Market Racing 3.5" Exhaust
BMS OCC & PCV (Boost side only)
N20 MAP Sensor
Eldor Coils
NGK 97506 @ .0020
255R 235F Pilot Super Sports on Breyton GTS-R Wheels
Motul Sport 5W40
E30 Fuel
Car: 2008 e92 335i
01-21-2020, 01:41 PM
No, I haven't messed with the duty bias, only fuel bias. I'm being very conservative right now with my boost to be safe.
Car: 135i N54
01-21-2020, 01:45 PM
17 PSI target with 20.3 PSI overshoot is not conservative. Any higher overshoot and the JB4 will toss you to map 4. My suggestion to raise the boost safety is to prevent that from happening.
Changing the duty bias will PREVENT your overshoot, thus being safer.
JB4 + Pump_USA BEF
VRSF 3" Pippys
VRSF 7" FMIC
HKS BOV
N20 MAP Sensor
Eldor Coils
NGK 97506 @ .0020
Motul Sport 5W40
E30 Fuel
Car: 2008 e92 335i
01-21-2020, 01:50 PM
Ok, I guess i was looking at it the opposite way. What should i set the duty bias to?
We have a very similar setup, can you post up screenshot of your JB4 User/WMI setting? The only thing I have you don't is the meth cp injection. Thanks.
Car: 2008 e92 335i
01-21-2020, 01:56 PM
Also I'm running the MHD hybrid turbo flash, does this flash factor in E50/60 blend, maybe that's why my HPFP is tanking?
Car: 135i N54
01-21-2020, 02:08 PM
Heres my log review thread: Take a look at the most recent log toward the bottom for my settings. I have some newer ones since switching to E30 fuel (those are on 91 Oct) if you need more info but I haven't posted them since I can self-diagnose.
No WMI or stage 2 LPFP for me. LPFP is next month tho.
Log Review Please - N54Tech.com - International Turbo Racing Discussion
As for your HPFP, its interesting as it really jumping around on pressure. I wonder if your sensor is starting to go, but it seems to hold 9-11 values (1350 to 1650PSI) during high RPM, which is barely hanging in there. Your trims are also OK.
Your AFRs are also leaner than mine, probably because of the E85 BEF you are running.
Timing also looks OK except for Ign5 which has a drop in 4th gear.
JB4 + Pump_USA BEF
VRSF 3" Pippys
VRSF 7" FMIC
HKS BOV
N20 MAP Sensor
Eldor Coils
NGK 97506 @ .0020
Motul Sport 5W40
E30 Fuel
Car: 2008 e92 335i
01-21-2020, 02:13 PM
Cool, thanks. Yeah my HPFP is not very old maybe 5000 miles it. Before my MHD hybrid BEF I was running the the PUMP_USA BEF and my fp_H values were better.
Car: 135i N54
01-21-2020, 02:19 PM
Oh and also, reset your FF to about 30 if you change settings. I had mine to high intially and overboosted the entire rev range.
JB4 + Pump_USA BEF
VRSF 3" Pippys
VRSF 7" FMIC
HKS BOV
N20 MAP Sensor
Eldor Coils
NGK 97506 @ .0020
Motul Sport 5W40
E30 Fuel
Car: 135i N54
01-21-2020, 02:21 PM
because you are running E50 fuel, I wouldn't switch back or your trims will max at 50 most likely. Only way to help out the HPFP is more meth or less boost.
how does it feel though? I see your calc_torque values are in the 60s which is a lot!
JB4 + Pump_USA BEF
VRSF 3" Pippys
VRSF 7" FMIC
HKS BOV
N20 MAP Sensor
Eldor Coils
NGK 97506 @ .0020
Motul Sport 5W40
E30 Fuel
Car: 2008 e92 335i
01-21-2020, 02:24 PM
Car feels good, pulls hard 3-4 gear. Turbos spool really fast. I know it has a lot more once dialed in.
Car: 2008 e92 335i
01-21-2020, 03:23 PM
Rustl3r, what map do you recommend running? Im currently running map 2.
01-21-2020, 03:33 PM
You need to disable FF gain- via FUD settings
You can help your HPFP by lowering boost, lowering ethanol content, or as stated increase methanol.
You can set your duty bias to mirror our hybrid settings & then relog map 1.
Car: 135i N54
01-21-2020, 03:40 PM
With FF gain disabled as Dave said above, recommend you switch to map 1 or map 4 and do a relog to see what your HPFP pressure behaves with the lower boost. If you still have no change in the "dips," I would think you have a bad sensor. Its tricky to tell though. The HPFP seal could be failing too, but usually that results in consistent bad pressure.
JB4 + Pump_USA BEF
VRSF 3" Pippys
VRSF 7" FMIC
HKS BOV
N20 MAP Sensor
Eldor Coils
NGK 97506 @ .0020
Motul Sport 5W40
E30 Fuel
Car: 2008 e92 335i
01-21-2020, 03:45 PM
OK, dont mean to be a noob but can you disable the FF gain in the JB4 bluetooth app? Im using the app not a laptop.
Car: 135i N54
01-21-2020, 03:46 PM
Yep, go to user map settings and scroll down to the future use area and select Bits, choice to disable FF gain should be in there.
JB4 + Pump_USA BEF
VRSF 3" Pippys
VRSF 7" FMIC
HKS BOV
N20 MAP Sensor
Eldor Coils
NGK 97506 @ .0020
Motul Sport 5W40
E30 Fuel
Car: 2008 e92 335i
01-21-2020, 03:52 PM
Ok, thanks. Yeah I’ve done all my own work to my car, I work on BMWs for a living but when it comes to all the different setting for the JB4 I get a bit lost.
Car: 135i N54
01-21-2020, 03:55 PM
All good. I did the work on mine as well. YouTube Educated lol.
JB4 + Pump_USA BEF
VRSF 3" Pippys
VRSF 7" FMIC
HKS BOV
N20 MAP Sensor
Eldor Coils
NGK 97506 @ .0020
Motul Sport 5W40
E30 Fuel
Car: 2008 e92 335i
01-21-2020, 04:23 PM
Oh nice, I’ll check it out! You have a vid of jb4 setting?!
Car: 135i N54
01-21-2020, 04:28 PM
No no for the turbo installation and all the related wrench work I used you tube and the BMW tech manuals for torque specs. I just checked out and played with every menu on the Jb4 app to familiarize myself.
Next up in IMPA and other BMW tools
JB4 + Pump_USA BEF
VRSF 3" Pippys
VRSF 7" FMIC
HKS BOV
N20 MAP Sensor
Eldor Coils
NGK 97506 @ .0020
Motul Sport 5W40
E30 Fuel
Car: 2008 e92 335i
01-21-2020, 09:08 PM
Ok, here’s another log with the adjustments. It went into map 4 right before I started the pull. And now my car is making odd noises. Need to look into that before anything else.
Car: 2014 335i
01-21-2020, 09:49 PM
The JB4 will tell you what caused the last map 4 safety. Check that out.
Car: 2008 e92 335i
01-21-2020, 09:54 PM
I think it was over boost.
I mirrored the “hybrid turbo” setting on the sticky thread. It was too much I think.
Thread Tools |
Display Modes |
