Ifreezebmx562 Ifreezebmx562 is offline
Car: N54 335i
Default N54 Exhuast sounds horrible after CLDP - 11-18-2019, 08:43 AM
Hello everyone, So i added some ARM 3" down P to my 08 N54.
After the down P install my car sounds exactly like a Honda.... i have a stock exhaust all my res and mufflers are installed, The only thing removed from the exhaust is the down P If anybody has had this problem PLS let me know what to do. At this point i dont even want to drive my car because of how bad it sounds...
Thanks for all the help!
N54 exhaust sounds horrible. - YouTube
I have a post on page 2 about my current codes according to carly.
codesx's Avatar
codesx codesx is offline
Default 11-18-2019, 10:36 AM
You're freaking me out. DeePees are on my winter install list.
But I like the DINAN sound, not the Civic...
Your description warrants a video! Do it! (not sure how one model DeePee can sound dramatically different than the next, but I've not done my reading on this subject yet)
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 11-18-2019, 11:15 AM
Does it run fine? If not you probably cross your O2s.
If it runs fine but sounds like ****, it's probably your cold start still being enabled. You are probably hearing the waste gates rattling.
Other than that make sure there are no exhaust leaks and that you installed everything right.
09 335 - 6266
07 335i - 6870, E85 - SOLD
Default 11-18-2019, 04:36 PM
Sounds like an exhaust leak, did you install the gaskets?
mattgu40 mattgu40 is offline
Default 11-18-2019, 07:34 PM
Exhaust leak or ***** vibrating on something / together.
Maybe the mid cats are in bad shape. Could add resonators
NA55 NA55 is offline
Default 11-18-2019, 08:46 PM
D P with stock exhaust won’t be much louder. You probably have an exhaust leak as others have mentioned.
Car: N54 335i
Default 11-20-2019, 01:59 AM
Hello everyone, I have gone to 5 different exhaust shops and they all said that my exhaust is fine. I installed the gaskets that came with it and all the bolts were 100% tight. I took it to a shop as well to see if anything was wrong with the deepee install and it was ok. Just sounds like sheeeit
Nachfolger Nachfolger is offline
Car: 09 E92 335i
Default 11-20-2019, 07:30 AM
If 5 independant shops told you it's fine, it's 100% just you. I'm not sure why it would sound much (or any) different, regardless.
You have yet to identify the difference, aside from saying it sounds bad. Not sure anything could be done to aid you.
codesx's Avatar
Default 11-20-2019, 09:55 AM
^^ Agreed.
Could always pop the hood to make sure they didn't toss a sewing machine under it.
I still vote, post a vid with audio, recorded from about 10 feet to the rear-side of the car. I'm fascinated by a sound that garners your description.
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Car: 2008 E93
Default 11-20-2019, 10:43 AM
Originally Posted by codesx
^^ Agreed.
X2
N54_ABQ's Avatar
N54_ABQ N54_ABQ is offline
Car: 2007 BMW E92 335i
Default 11-20-2019, 10:53 AM
Do you use JB4?
If so, I've found (with my car at least) that if option 10 (Default Wastegate Position) is set at or near 0 it sounds like crap.
When the setting is 0 the wastegates are WIDE open during low throttle and cruising.
My car will sound like beer cans are rattling in the exhaust until I give heavy throttle and the WGs close. I keep the setting maxed out at 5000.
It's more than WG rattle its raspy and tinny sounding. Sounds like well... a beater Honda.
2007 335i E92 6MT FBO, Stock Turbos
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 11-20-2019, 10:56 AM
Could be the big round gasket on the turbo side to the ** if fallen off could be leaking from there
inline6xi inline6xi is offline
Car: 2008 bmw 535xi
Default 11-20-2019, 11:25 AM
I Installed ***, and honestly I wish I could tell the difference. no noticable difference from stock, with stock exhaust. Something is up, dude.
codesx's Avatar
Default 11-20-2019, 12:47 PM
Rubbish. I'm expecting 25% more sound volume.
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Car: 2008 bmw 535xi
Default 11-20-2019, 02:37 PM
I can't tell if you are being serious
codesx's Avatar
Default 11-20-2019, 02:42 PM
I've never done deepee, so no personal experience.
I plan on it this winter, for performance, but was believing it would let through more sound.
I like my sound, but want a bit more of it.
Not the case from what your saying.
I'm not sure if YOU are serious! Lol
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Car: 2008 E93
Default 11-20-2019, 07:56 PM
Hearing aid and call it done 🤣
Car: 2008 E93
Default 11-20-2019, 07:59 PM
So if just *** sound that bad, maybe the seals on turbos where the ** meets at the flange. Possibly a bad weld at an 02 bung ?
Hard to say without a video.
Op where are you located ? I see 562 in username.
Car: 2008 bmw 535xi
Default 11-20-2019, 08:50 PM
Im dead serious. I really cant tell the difference. my turbos are much louder after upgrade, but I cant tell a difference in the exhaust at idle or while driving.
codesx's Avatar
Default 11-21-2019, 10:47 AM
Hearing aid and call it done ��
LOL. They're more expensive than a muffler delete!
Very nice looking work and pics.
How long did you spend?
That was laying on your back, or a lift?
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Car: 2008 E93
Default 11-21-2019, 11:18 AM
Oh, well
Carry on then
Car: 2008 bmw 535xi
Default 11-21-2019, 11:24 AM
Thanks. I did it in my garage because I wanted to take my time. I can be a little obsessive when it comes to details.
That being said it's impossible to say how long for just the cats, as I pretty much addressed the entire front end maintenance while I was down there. Shout-out to AR designs, as I had to literally Fab a notch in the front ** so the rear upstream O2 sensor could clear, and I could rotate the front ** to the correct position. Was pretty bummed, but if there's one thing this project taught me it's this: if you deal on the internet, you gotta deal with the internet. Taking time to ship them back and then maybe get a part that fits 100% correctly a month later wasn't as interesting to me as just solving the problem in my garage, same day.
I documented my work pretty well with pictures, so I should probably do a build thread. I'm definitely one of few, if any e60 awd guys that has done the pure 600 turbos, and aluminum outlets.
Car: 2008 E93
Default 11-22-2019, 02:31 PM
So no videos of exhaust ?
BryGuy11's Avatar
BryGuy11 BryGuy11 is offline
Car: 2007 BMW 335i
Default 11-23-2019, 05:28 PM
"At this point i dont even want to drive my car because of how bad it sounds..."
I wish more Honda owners felt this way !
101st Airborne Infantry Vet.
07 335i e92, FBO, VTT turbos, 18 psi on 100 octane, a few ///M3 goodies, and ///M3 parts.
Car: 2008 E93
Default 11-23-2019, 11:55 PM
LMMFAO !!!!!
