Originally Posted by Vorsprung_CJB
Did you copy the BMS data into your original BIN with TunerPro or just use the BMS file straight on your DME?
I have not copied any data. I have only performed the steps as spelled out in the thread ('BMS/MHD Backend Flashing Flow Chart').
The tablet has been 'factory reset' within the past month... clean wipe / install of OS. Could I have lost settings or files required for quick 2min updates?
After the tablet reset, MHD Flasher went thru a "long write" successfully. Now able to updated with 2min writes. I may have updated the BEF two times previously since the tablet reset without issue.
Also note that when performing Start/Resume Backup it connects but says “DME read protected”
