Car: 2008 e92 335i
Finally did some logs!! Input would be great!! -
09-07-2019, 02:36 PM
Here they are, see attached photos.
Car: 2008 E93
09-07-2019, 03:45 PM
Boost is under target, AFR seems ok as well as trims , throw up a csv to better see everything.
Car: 2008 e92 335i
09-07-2019, 04:27 PM
Ok, here are the CSV file
Car: 2008 e92 335i
09-07-2019, 04:28 PM
Yeah I always felt my boost was low, but my car runs so well at the current boost didn’t really look into pushing more boost.
Car: 2008 E93
09-07-2019, 05:29 PM
Quite a few things here. Boost probably under because of duty bias settings. Trims start crashing a bit but probably because fuel bias settings.
First things first,
1. Update firmware
2. Set ALL default settings INCLUDING Tmap, 6cyl, FF (Which is maxed at 150 but duty cycle is not maxed so doubt its a boost leak but still possible), then log again.
3. List mods and fuel plz.
Car: 2008 e92 335i
09-07-2019, 05:59 PM
First things first,
1. Update firmware
Awesome! Thanks for the input Beast. I will go ahead and do that and do more logs.
Car: 2008 e92 335i
09-09-2019, 08:41 PM
@the beast, ok did what you said, updated the firm ware, I think I set most everything to default and drove it around a little. Holy sh*t. I thought my car was fast before. Still need to do some logs.
My current mods are FOB, running e30/40 and meth injection in charge pipe. I just got a stage 2 LPFP that I need to install.
09-09-2019, 09:03 PM
Throw up logs w. Eveything set to default - map 1 is preferred
Car: 2008 e92 335i
09-09-2019, 11:33 PM
Ok, here are some logs from tonight. As for “default” is there a default button that will set everything to the default setting? I’m using the jb4 mobile app for IOS. Sorry if that’s a dumb question. Also does that include the meth setting as well?
Car: 2008 E93
09-10-2019, 08:31 AM
Map 1 or 2 is preferred for safety. Default settings have to be done manually .fuel bias is still not set, or tmap, or 6cyl, just what I saw at a quick glance.
Car: 2008 e92 335i
09-10-2019, 08:46 AM
Ok, I'm going to have to figure out how to reset everything to default. This logging is a whole new part of the game and I need to educate myself on.
09-11-2019, 10:26 AM
E Series N54 JB4 - N54Tech.com - International Turbo Racing Discussion
Post # 3
Car: 2008 e92 335i
09-11-2019, 01:58 PM
Hi Dave, yes it took a little time but I found that post! Ok here's my latest log with everything set to default. My issue is now im not getting any meth activation. I did a few WOT pulls but still not getting anything for meth.
09-11-2019, 04:45 PM
Does it flow on map 3?
Car: 2008 e92 335i
09-11-2019, 08:18 PM
No, it doesn't flow on any maps. I even went back and put it to the settings i had it before when it was working. Whats weird is that the meth flow on the oil temp doesn't indicate the system is on, it shows oil temp. I tried to purge/prime the system through the app it doesn't do anything but if i do it through the steering wheel setting it worked. So at least i know it's not a component issue.
Other than this the car running great!
Car: 2008 e92 335i
09-12-2019, 01:33 PM
Here is my meth setting. I'm going to mess with it some more tonight but still not sure why im not getting flow.
Thread Tools |
Display Modes |
