Car: 2007 e92 335i
Hybrid log, please check it out, thank you -
08-10-2019, 09:10 PM
2007 Bmw 335i, log done on map 2
manual
maintenence is up to date
index 12's, walnut blast, bosch coils, brand new ngk 97506(.022)
hexon rr550(newly rebuilt)fbo, ******* *********, remus exhaust, charge pipe, tial, 5 inch stepped intercooler, stage 2 lpfp, e40 mixed with 91
It builds boost so slow, no check engine light
What is your input on the log?
Thank you
08-10-2019, 09:49 PM
Which flash did you load?
Car: 2007 e92 335i
08-11-2019, 01:13 AM
I8aeos hybrid e85
08-12-2019, 01:01 PM
Try setting dwp to 70 & relog
Car: 2007 e92 335i
08-12-2019, 07:06 PM
Roger that
Car: 2007 e92 335i
08-12-2019, 07:07 PM
And thank you.
08-13-2019, 09:54 PM
Don’t mention it. Will get it sorted
Car: 2007 e92 335i
08-16-2019, 02:15 PM
Dave, what about the low fuel pressure from the lpfp? It's dipping really low, but the pump is a new stage 2 pump and has maybe 800miles on it? Any suggestions to get more fuel?
Running e40~
Car: 2007 e92 335i
08-17-2019, 06:38 PM
Dave, heres another map 2 log, lpfp is stilll low after resetting adaptations. the stage 2 pump is new, almost 800 miles on it. Should i lower the e content? Whats your thoughts?
Car: 2007 e92 335i
log -
08-17-2019, 06:49 PM
Please have a look
08-17-2019, 07:31 PM
Yeah run either less ethanol or less boost
Where’s the pump from? I’d check for physical kinks in line when u pull the pump to examine
Car: 2007 e92 335i
08-18-2019, 11:51 PM
I bought it from a forum member that specializes in building them.
08-19-2019, 12:00 PM
For an upgraded LPFP - the mid 50's is awfully low, even w. hybrids- something has to be up.
I'd contact whomever the pump was purchased on, and ask for a little assistance there- just to ensure the pump itself isn't the culprit.
Until then- try dropping the ethanol content.
Car: 2007 e92 335i
08-20-2019, 05:20 PM
Thanks k you Dave. Since I'm at elevation(5000 ft above sea level)should I set duty bias and fuel bias all back to 50?
08-21-2019, 11:23 AM
You can yes.
Thread Tools |
Display Modes |
