Voodoo Priest Voodoo Priest is offline
Car: 2007 e92 335i
Default Bef, which ots maps for fbo, Hybrids and stage 2 pump? - 08-08-2019, 10:37 AM
Hello gents,
I want to try to get my car going, so I need some help please.
2007 BMW 335i n54 , maintenance is current.
New index 12's
Bosch coils
Vc gasket
Ofhg
Occ
Currently on ngk 95770, just ordered 95706 from burger
Hexon rr550 ,fresh rebuild
Stage 2 pump
Fbo
Jb4 with bef.
I run e30.
Which map should I start on or be on?
Thank you
Car: 2007 e92 335i
Default 08-08-2019, 10:41 AM
Also has had walnut blast late last year
Default 08-09-2019, 07:01 AM
Hybrid flash of running e30
Car: 2007 e92 335i
Default 08-09-2019, 12:38 PM
Thanks Dave, but when I go into mhd I have these it's map selections:
I8aos.race
I8aos. Hybrid e85 pi lowtiming no spool
I8aos hybrid race
I8aos pump
I8aos pump USA
I8aos hydrid e85 pi
I8aos hydrid e85
I8aos e85
Which one? And does pi stand for "port injection"?
Default 08-10-2019, 06:46 AM
If memory serves me well- the hexon550 isn’t a “big hybrid”
Hybrid e85 or the stock turbo pump flash would work if using e30
& yes Pi = port
Car: 2007 e92 335i
Default 08-10-2019, 01:10 PM
Hi Dave, theyre a 15t turbo. So the settings on the first page of this thread, start with that, then log?
Default 08-10-2019, 03:49 PM
Set your DB settings & FUD settings appropriately (hybrid)- and yes log map 1
Car: 2007 e92 335i
Default 08-10-2019, 08:57 PM
Dave, how do i do that? im very new to this.
Default 08-10-2019, 09:46 PM
User adjustment tab will give you access to the DB settings & FUD settings.
Read our hybrid turbo sticky thread to get the correct values to input
