unknownz24 unknownz24 is offline
Car: 2008 335xi
Default Check in Data Logs - 05-19-2019, 09:12 AM
I've been running the BEF PUMP for a bit now after my initial check-in with you guys, and wanted to throw some new logs your way for your review and comments.
Mods are:
-BMS DCI
-Stett Charge Piping and inlets
-RB turbos (specs unknown)
-CPE Front Mount IC
-C at Less Down Pi pe s
-Running 93 octane
Also wondering where I can find some reading material on Map 6 to see about bumping up a tad.
Thanks in advance!!
Car: 2008 335xi
Default 05-19-2019, 09:30 AM
And here was the best run of the night
Default 05-19-2019, 03:12 PM
Overall the log looks pretty solid.
Turbos have more in them for sure.
Fueling wise your LPFP looks about maxed up top. If we were going to bump things up- Iíd Rec an LPFP upgrade.
Car: 2008 335xi
Default 05-19-2019, 06:32 PM
I'm listening heh
What stage do you recommend? I'd like to go meth one day, as 93 octane isn't going to be available in the area in moving to in a few years.
And how much of a PITA is the fuel pump install? I assume it's in tank?
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-19-2019, 07:05 PM
I'm listening heh
Not that hard to install
BMW 135i and 335i Stage 2 LPFP installation
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Default 05-19-2019, 08:38 PM
I'm listening heh
Our bucketless is probably the most popular choice & would give you plenty of headroom.
Car: 2008 335xi
Default 05-20-2019, 12:59 PM
Originally Posted by Haynpunch
Solid, I was worried it was a drop the tank sort of situation
Car: 2008 335xi
Default 05-20-2019, 02:45 PM
Do you mean the bucketless stage 2? Does it need Hobs switches? I like the idea of maintaining the bucket like on the stage 2 with bucket, but don't like the prospect of burning out the fuel module.
What is the stage 1 in line capable of supporting?
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-20-2019, 04:50 PM
No Hobb switch needed
Bucketless
BMW E-Series Walbro Stage 2 Bucketless LPFP Upgrade - FUEL-IT!
Bucket plug n play
BMW E-Series Walbro Stage 2 LPFP Upgrade - FUEL-IT!
Bucket / Transfer your existing float, top hat
BMW E-Series Walbro Stage 2 LPFP Upgrade (DIY) - FUEL-IT!
07 E90 AT - xHP
FBO
Hybrids
Car: 2008 335xi
Default 05-30-2019, 10:51 AM
Installed the stage 2 bucketless LPFP and did some a few pulls in 2nd and 3rd gear.
Not sure if 2nd gear pulls are useful for logs, but it's easier to find a road for a 2nd gear redline than a 3rd gear redline lol
Default 05-30-2019, 11:51 AM
2nd isnít great for logging
Your 3rd gear logs look really clean- HUGE improvement in the LPFP. You can jump up to the next map if you wanted to push it a bit more.
Car: 2008 335xi
Default 05-30-2019, 11:53 AM
Yes please! Haha
Default 05-30-2019, 11:56 AM
Yes please! Haha
Car: 2008 335xi
Default 05-30-2019, 11:59 AM
Should I go map 7? Or 6 with adjustments?
Default 05-31-2019, 12:13 AM
Letís see 7 & evaluate
Car: 2008 335xi
Default 05-31-2019, 11:54 AM
Great! I'll get some pulls in tonight.
Just to confirm, you don't need to do adaptation pulls when switching between maps?
Car: 2008 335xi
Default 05-31-2019, 11:42 PM
Did a few pulls in map 7, mostly kicking me into map 4 for over-boosting.
Thoughts? Thanks again for your help, Dave
Default 06-01-2019, 02:15 PM
Looks like your hitting boost safety- bump that up to say 20 or 21
do that & relog- cyl 5 looks to be down a bit on timing too- will keep an eye on that
Car: 2008 335xi
Default 06-01-2019, 02:26 PM
I still have the stock TMAP, going to 20-21 is fine?
Agreed, I noticed cylinder 5 is usually down on timing near the top end. I haven't done plugs on this car since I picked it up a few months back. Would it be appropriate to got with the 2 step colder plug around this level of tuning?
I'll run a few pulls tonight
Default 06-03-2019, 12:05 AM
Yup- go with a 1 or 2 step colder plug & gap appropriately
Stock tmap- set boost safety to 20, it should let you do that
Car: 2008 335xi
Default 06-03-2019, 10:52 AM
I swapped out the cylinder 5 coil and moved it to cylinder 1. The timing error moved to cylinder 1, so I have a new Delphi coil on the way. Once that comes in later this week, I'll reattempt some pulls based on your recommendations
Also ordered some NGK 97506 because the NGK 5992/95770 are all back ordered everywhere. I'm now thinking the 97506 might be TOO cold for the boost level/timing I'm running? Guess we'll see!
Thanks for the continued support!
Default 06-03-2019, 12:27 PM
I run those same plugs on a virtually stock 335, no issues.
Gap to .020
Car: 2008 335xi
Default 06-07-2019, 11:23 PM
Gapped and installed new plugs, replaced the failing coil, no more misfires!
Still getting kicked back down to Map 4 because I'm exceeding the boost safety. I've set it to 21 psi, the JB4 mobile won't let me set it any higher than 21.
Was able to get a clean run of my first pull, all the other got kicked into Map 4 for boost safety.
Time for a new TMAP?
Haynpunch's Avatar
Car: 07 E90 335i
Default 06-07-2019, 11:51 PM
neither of these logs kick you into Map 4
If you are trying to target anything above 21 you should upgrade the TMAP
07 E90 AT - xHP
FBO
Hybrids
Car: 2008 335xi
Default 06-07-2019, 11:58 PM
The second log doesn't show map 4, but you can see the target boost drops to 8psi
On the JB4 mobile it was definitely in map 4 after that run.
If the log looks clean and there's room to go up still using 93 octane, maybe TMAP is the next move
