Haynpunch's Avatar
Car: 07 E90 335i
Default NGK 95770 Sold Out - 04-23-2019, 03:17 AM
Whatís going on with NGK 95770 being sold out everywhere?
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
nefariousminion nefariousminion is offline
Car: 08 535i
Default 04-23-2019, 07:22 AM
Also waiting for these... I cant recall if it was bimmerworld or another vendor that was estimating end of april, but here we are and...
with fbo and hybrids wouldnt you want to go 2 steps colder? n20 or s55 plugs? I havent pulled that trigger since im fbo on stockers.
535i E60 6MT: VTT Wastegate Fix / BMS DCI / No name Dpipes & CP / ARM 7" FMIC & Hose Upgrade / VRSF Inlets
C5 A6 2.7T 6MT
GotPwned GotPwned is offline
Car: 2007 BMW 335i
Default 04-23-2019, 08:01 AM
BMS still has the 95770s in stock and they are going for 11 bucks a piece
Car: 08 535i
Default 04-23-2019, 08:11 AM
Where are you seeing that? Im looking at their website now and I'm seeing 5992 (now 95770) as out of stock, oem bosch and 97506 available.
C5 A6 2.7T 6MT
Default 04-23-2019, 09:01 AM
NGK has a worldwide back order on these with no ETA. You won't get them anywhere unfortunately.
The NGK 97506 is a great alternative, I would go with those over OEM Bosch IMO.
We have plenty of both in stock though!
https://www.burgermotorsports.com/pr...ch-price-15-00
https://www.burgermotorsports.com/pr...n54-spark-plug
Car: 2007 BMW 335i
Default 04-23-2019, 09:33 AM
I checked yesterday and they were still in stock. I guess they sold out.
theobjectivist theobjectivist is offline
Car: 2008 535i
Default 04-23-2019, 10:41 AM
bummer - im in the exact same boat. I wanted to get it ordered and change coils/plugs this weekend.
Im interested in the 97506 VS 95770 though. What makes the 97506 a good alternative?
I see that theyre 2 steps colder and have slightly different dimensions. They dont induce a sketchy idle or other unwanted behavior, right?
Im running:
17-25PSI with RB next gens
Delphi coils
~E20-E30 fuel
Default 04-23-2019, 10:56 AM
Im running:
Delphi coils
~E20-E30 fuel
I haven't had any of those issues stated above. When going from the 95770 to 97506 I never had a misfire issue with 700+whp on my car. I recommend that to everyone with a .020-0.22" gap.
Car: 2008 E93
Default 04-23-2019, 12:55 PM
Agreed
Car: 2008 E93
Default 04-23-2019, 12:57 PM
Im running:
Delphi coils
~E20-E30 fuel
Idles PERFECT. I have never had an idle issue though with stock, 1, or 2 step colder.
No ill behavior either.
Car: 08 535i
Default 04-23-2019, 01:49 PM
Good to know about the idle behavior. Besides the decreased service interval, I think the less thorough burn is my concern. Rich mixture wearing out 02's, and I already have a little smoke cloud behind me in traffic But I think it's a no brainer if you're anything over stock turbos.
Can anyone comment on running smaller gap to keep coil voltage in check? Im concerned about my MSD80 mosfets going out
C5 A6 2.7T 6MT
Car: 2008 535i
Default 04-23-2019, 03:41 PM
Are you saying the 97506 plugs have reduced life and/or dont burn as well as the 95770s?
Car: 08 535i
Default 04-23-2019, 03:57 PM
Iím not well enough researched to say for sure. But Iíve been told that 95770 will need to be replaced more frequently than stock, someone here said difference between 97506 and 95770 isnít as big a deal. Bimmerworld has a page on this
C5 A6 2.7T 6MT
FEDE/E92 FEDE/E92 is offline
Default 04-23-2019, 05:35 PM
Twisted tunnin has some
Car: 08 535i
Default 04-24-2019, 06:54 AM
Someone must have beat me to it, sold out now
C5 A6 2.7T 6MT
nissubaru nissubaru is offline
Car: 2009 335i M-Sport
Default 04-24-2019, 08:12 AM
What about ebay?
NGK 95770 | eBay
Default 04-24-2019, 09:15 AM
Originally Posted by nissubaru
What about ebay?
NGK 95770 | eBay
Beware buying plugs off ebay. Half of them are counterfeit
SPANKY's Avatar
SPANKY SPANKY is offline
Car: 2008 335i
Default 04-24-2019, 09:53 AM
How would the Ngk 97506 plugs work in fall winter months,since they are 1 step cooler then ngk 95770?also would running the 97506 over 95770 benefit cars with about 600rwhp?or are these plugs more for 700plus hp cars.
E90 SEDAN '08
-SiNGLE TURBO AUTO TRANS*FSB G5 ISO*100%METH**FUEL iT!STAGE 2*ALPiNA FLASH-
-NGK PLUGS*BMS OCC*RB VALVE-
-E85 MHD FLASH-
Car: 2008 E93
Default 04-24-2019, 10:06 AM
I run these at 600whp with no issues. Even if i turn boost down to about 550, no issues. Winter ? Im in SoCal so it hits low 40s high 30s at its coldest.
Car: 2008 535i
Default 04-24-2019, 10:51 AM
on your and payam's advice, i just bought them -my fingers are crossed they work well on lower powered cars too
who ever heard of a company running out of spark plugs? lol
Car: 08 535i
Default 04-24-2019, 11:56 AM
I think NGK decided there werent enough sales to continue production. I cant find what car these were originally intended for. Our platform came out 10+ years ago, they probably figure well just get 97506 if we dont want oem. Shame because 95770 seemed to suit fbo pretty well.
C5 A6 2.7T 6MT
Default 04-24-2019, 01:52 PM
National back order, use the 2step colder instead. Which are the same heat range used on the N20 motors. Better plug anyway and not much more.
Ohios52carter Ohios52carter is offline
Car: 08 e90 335xi
Default 05-03-2019, 04:53 AM
I'll have my set of 95770s when I get off of work. Had auto zone look up the part number and send to store. Under 80 dollars...
Default 05-03-2019, 10:38 AM
They probably had a few left in stock, you got lucky!
N54_ABQ's Avatar
N54_ABQ N54_ABQ is offline
Car: 2007 BMW E92 335i
Default 05-03-2019, 03:22 PM
Just installed a set of NGK-97506 along with a set of new coils. Runs Great!! Gapped them in at .020" to start and seems to be perfect for my setup.
I was concerned about cold start misfires being 2 steps colder but not a sign of missing this morning at 50F.
2007 335i E92 6MT FBO, Stock Turbos
