DeepEddy DeepEddy is offline
Car: E92
Default Need help with logs new ST - 02-23-2019, 03:35 PM
New to the forum and finished a single turbo install.
to prevent confusion I did not realize we had a log and review section so please disregard my indentical post on the single turbo thread.
MY car a E92. Spec2+ and a aluminum flywheel. I have a single Walboro 450 lpfp currently. I have one step colder NGKr plugs gapped at 0.023".
For the tune im running a JB4 and MHD ST E85 Bef. I fill up with E60-70.
Purchased and installed On3 gt35 journal bearing kit. I have a 12pound spring on order but there kit comes with a 7pound spring that I have currently installed. And PR coils.
I drove around on Map 1 to break everything in for almost 500miles, and make sure my plumbing on the mac solenoid is good. Found free time and a private place to move forward with map2 and log. I logged about five runs and have included the best one of the day. My boost raises to almost 16psi before it dives and im not sure why. I see bank one afr is a bit hectic and possibly my sensor is failing. Can someone help me and take a look at this log and give me a bit of advice.
FEDE/E92 FEDE/E92 is offline
Default 02-23-2019, 05:58 PM
Not sure 100% sure if related but turn off all meth settings
PrzeChuj PrzeChuj is offline
Car: 08 335i
Default 02-23-2019, 06:04 PM
I will try ,I jist tried a log and still the same so I definetly will give it a shot in a few
e92 MT 08
Single T
FBO
Dual 450 lpfp
BEF
MeTH!!!!!
E85 100°/¤
Car: E92
Default 02-23-2019, 06:41 PM
All meth settings are off on this log
Car: E92
Default 02-23-2019, 06:44 PM
I also reconnected my clutch wire and turned off FUD settings. The two step on a single is to just to good.
Default 02-23-2019, 08:19 PM
Pid Gain should be set at 25. I think u need bigger spring. FF dwp pretty high.
Default 02-23-2019, 10:40 PM
I’d cruise around on map 1 for the time being- swap in the heavier spring when you get it.
Car: E92
Default 02-24-2019, 05:48 AM
Thanks for that guys. Just a wairimg game for the time being
Default 02-24-2019, 10:19 AM
Car: E92
Default 03-01-2019, 06:23 PM
I finally replaced my old 0.5 bar spring with a new 0.8 bar spring a bit over 11 pounds. And i most definetly fell the diffrence . I attached two logs for some advice or pointers. I brought my plug gaps down to 0.019" and turned meth on all maps.
Hyab00sta Hyab00sta is offline
Car: 09 335xi
Default 03-02-2019, 08:01 AM
slight overboost, all the lines on the pressure side of the solenoid straight and not pinched or bent? I had to use a 90 adaptor off my compressor housing because it was bending my vac line with the filter on and causing me to overboost by 2 psi.
Default 03-02-2019, 08:26 AM
Set your DB to 50 across the board in your user adjustment settings
Relog
Car: E92
Default 03-02-2019, 08:40 AM
Will double check the lines . I need to replace with stainless steer one's, very very near future. Going outside to change settings to 50, will relog in the morning. Thanks you Dave and hyaboosta.
Default 03-02-2019, 04:17 PM
