Car: M140I
MAP 6 M140i Log Throttle Closure -
01-07-2019, 06:21 AM
Hi Guys,
Started messing with Map 6 from a settings I have seen posted by different users.
Any ideas how to eradicate the Throttle Closure? Tried FUA @ 20 working down to 10 and this gets rid of the throttle closure but loose quite alot of boost?
Any help would be great.
Log Attached
01-07-2019, 12:11 PM
You're overboosting by a lot that's why you're having throttle closures to regulate the boost.
I would go down to a preloaded map before moving up to map 6 if you're not sure what you're doing or looking for.
Can you get a log on map 2, what fuel are you using?
Car: M140I
01-07-2019, 12:29 PM
Hi Payam,
I sent some logs in on a previous thread to look over as I was having issues then, Map 2, Map 3 & Map 5 were all having the same issue.
That's why I have gave MAP 6 a try. I have posted the Logs on a previous thread only a couple down from this one
01-07-2019, 12:39 PM
Issue is DME BT wobbling, there is no fix for that problem. So you have to set the tuning such to avoid it.
Car: M140I
01-07-2019, 12:46 PM
Terry/Payam,
Is there anything I can do just to lower it slightly? If I reduce target boost? Or any settings. Car is so near to perfect now after a couple issues with the car in past
Car: M140I
01-07-2019, 01:59 PM
Map 2 as requested, hopefully you can see something from this?
Also I attached a MAP 3 with slight adjustments and this looks much better but is the boost correct?
Hopefully you can help as I would love to go further with the car but want to get it right at this power first
Thank you guys for taking your time to look at this
01-07-2019, 04:05 PM
Seems to be hit and miss, stay with map3 and see if you can hang on to that.
Car: M140I
01-12-2019, 02:28 AM
Stood with MAP 3 and it seems to have sorted itself somehow and the throttle closure just vanished ?
Thanks very much for your help! Any pointers on starting MAP6 as people seem to be getting great results
01-15-2019, 07:03 PM
Easy fix works for me. The B58 just likes to act out sometimes.
I'd stay with one of our maps unless you're looking for a part time job logging and adjusting your car.
Thread Tools |
Display Modes |
