Boostd435 Boostd435 is offline
Car: 2015 435i
Default HELP! JB4 + BEF running too rich - 11-04-2018, 10:27 PM
Just installed BEF with MHD and my CEL keeps popping up. When I read the code it says fuel mixture is too rich. Not sure on how to fix. I also set the burble aggressiveness to max when flashing if that is worth noting. Current mods are VRSF FMIC and CP, Injen CAI, Stock **. Not running any e85. Logs included below.
WeekendWarriorz WeekendWarriorz is offline
Car: 2012 135i N55 DCT
Default 11-04-2018, 10:45 PM
Did you flash the right bef? You're EWG I believe
2012 BMW 135i DCT, Late E series. VRSF meowless, ARM chargepipe, VRSF 7.5in race FMIC, Fuel it! Stage 2 LPFP- Sold
Car: 2015 435i
Default 11-04-2018, 10:49 PM
Yes i flashed EWG pump flash.
Default 11-04-2018, 10:53 PM
Did you select "bit6 - Vehicle is equipped with a back end flash map" in the FUD settings?
Car: 2015 435i
Default 11-04-2018, 10:57 PM
no, what is FUD
Default 11-04-2018, 11:01 PM
no, what is FUD
Alright that's your issue, Click on the Future use D bit in either the Jb4 mobile app or in the user adjustments page on your computer, then select "bit6 - Vehicle is equipped with a back end flash map", after than reset your ff/wastegate adaptation to 60
Car: 2015 435i
Default 11-04-2018, 11:07 PM
thanks my guy, will check tmrw to see if its running fine
Default 11-04-2018, 11:12 PM
That should fix your issue, take a 3rd or 4th gear log from 2500rpm to 6500rpm and turn off traction/DSC if you can (don't crash), make sure you change your ff/wastegate adaptation. Post a log and someone or myself can read it for you
Default 11-04-2018, 11:37 PM
AFR isn't rich. What's the exact fault code?
You'll need the EWG connector installed to take advantage of the higher boost targets on the BEF.
Car: 2015 435i
Default 11-04-2018, 11:55 PM
Code is 118002 mixture ecu: mixture too rich
Car: 2015 435i
Default 11-05-2018, 11:32 PM
log
Default 11-05-2018, 11:44 PM
log
That log looks much better, do you have the EWG connector?
Car: 2015 435i
Default 11-06-2018, 03:36 PM
Just ordered the EWG connector should be coming in within the next couple days. Car is still throwing the CEL and getting same code despite adjusting the parameters. Hoping the connector will solve this issue. Maybe clean the maf sensor?
Default 11-06-2018, 03:38 PM
I believe you need the connectors to run a bef. Since the boost targets are higher in every map. Put in the connectors then retry. Make sure you unplug the battery when touching the jb4/wires.
Car: 2015 435i
Default 11-12-2018, 01:30 PM
I have installed Ewg connectors, still getting CEL. Same code (mixture too rich). here is a log:
Default 11-12-2018, 03:26 PM
Looks like just a fault that needs to be turned off or adjusted in the BEF to match the E85 mixture. What fuel mix?
Car: 2015 435i
Default 11-12-2018, 08:44 PM
Running pump flash on 91. no e85 in the tank (not so abundant where im from).
JLBimmer's Avatar
JLBimmer JLBimmer is offline
Car: 2016 435ix GC
Default I am having the same issue - 08-23-2019, 10:37 AM
What happened and what was the resolution?
JL Bimmer
2016 435ix Gran Coupe
HRP Cold Air Intake, Charge Pipe, Turbo Up Pipe, Turbo Intake Pipe, BMS Intercooler, Axle Back Exhaust, JB4
H&R Springs, Sways, Strut Tower bar, 19"x10 Rotiforms, Too much carbon goodness
