Car: Bmw 335i ST
335i stock turbo @19.5psi dyno -
07-19-2018, 08:23 PM
07-19-2018, 08:44 PM
nice bro
Car: 2009 135i alpine white
07-19-2018, 09:00 PM
Dern. Great job.
07-19-2018, 11:13 PM
Nice #s
Car: Bmw 335i ST
07-19-2018, 11:50 PM
Originally Posted by Dave @ Fuel-it!
Nice #s
nice numbers w horrible out temp
Car: BMW 335i N54
07-20-2018, 03:15 AM
Resolution is so low; Can't read anything. What's it saying?
Car: 2007 e90 335i
07-20-2018, 03:34 AM
What fuel is this on?
2007 e90 335i
Car: Bmw 335i ST
07-20-2018, 09:34 AM
e30 mix @19.5psi
Car: Bmw 335i ST
07-20-2018, 09:35 AM
ill try to get a better pic from owner
Car: 335i E92
07-22-2018, 07:23 AM
What numbers was it making? Sorry can't really make it out of the picture due to low quality. E30 mix with 91 or 93?
Car: 2008 E93
07-22-2018, 10:56 AM
Thats a LOT of torque to get that thing moving
Car: 2008 E93
07-22-2018, 10:57 AM
91 or 93 wouldnt matter? Still E30 either way.
Car: 2008 E93
07-22-2018, 11:32 AM
Originally Posted by bmweurotuning
Can you post a better pic of the dyno sheet ?
Car: Bmw 335i ST
07-22-2018, 11:42 AM
the car is a 2009 bmw 335i 6 speed manual
mods : Jb4,Dci's, Bms BEF, Running e40, New 335is clutch.
3 pulls were made @102f outside temp... after 1 hr run car on dyno again and the outcome was 420hp, 520tq. @ 19.5 psi. i will post new dyno data sheet after couple mods coming up.. it should be around 540hp @22psi. 5xxtq.
Car: e92 335i
07-23-2018, 02:39 AM
Im assuming you meant 440whp, 120whp off 3 psi would be insane
Car: 335i MSport DCT
07-24-2018, 09:55 AM
I expect this is all crank horse power.
You wouldn't get 500whp from stock turbos on a proper dyno.
UK FBO 335i, ̶V̶T̶T̶ ̶G̶C̶s̶ China 19T, JB4, PI meth, BMS CP, OCC, Braided brake lines. Diff Lockdown. TMAP sensor, custom bucketless stage2
Car: Bmw 335i ST
07-24-2018, 10:01 AM
this is not crank horse power is to the wheels and yes you can go over 500 on stock turbos if you know how to build your car and have a professional tuner that knows what he is doing!
Car: 335xi, 335i
07-24-2018, 06:48 PM
I have heard 500whp is possible on stockers but they will live a short life. I say no way to 540WHP regardless of any magical tune.
335i FBO,Meth,JB4,Sutphin flash,LSD,GCLites 11.25@127.4 on NT05R
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C
Car: Bmw 335i ST
07-24-2018, 07:01 PM
its not only about the tune. you also have to have proper fuel such as upgraded fuel pump Lpfp and add port injection on your hpf side + adjust other components w jb4 as needed based on logs.... and yes it its possible 540hp on a cold day lets say weather temps 65F.. @22psi on a fbo 335i ... keep on mind anything more than 22 its not reccomended since turbos dont make any more pwr...
Car: 335xi, 335i
07-25-2018, 11:35 AM
How much boost are you hoping to see at redline to make 540WHP?
Car: Bmw 335i ST
07-25-2018, 11:50 AM
you dont redline on stock turbos , after 6krpm stock turbos dont make more pwr. i can achieve 540whp at 21psi w proper fuel pi, meth e85 ...
Car: Bmw 335i ST
07-25-2018, 11:54 AM
and your answer is at redine 10psi
Car: 535i
07-25-2018, 03:33 PM
what exactly do you recommend to achieve 500rwhp on stock turbos, planning on swapping mine for a brand new stock set
Car: Bmw 335i ST
07-25-2018, 03:37 PM
Besides all bolt ons, you will need port injection, and a stage 3 low pressure fuel pump, along w a good tuner who can fine tune boost target. At certain rpms etc.. Also make sure all your spark plugs are up to date ign coils, get colder plugs. Step 2. At least .
Thread Tools |
Display Modes |
