Car: 2008 E93
Default Fueling question - 07-01-2018, 10:34 AM
How far can we push the HPFP on the N54 with E85 and pi ? I mean even with pi, the hpfp at some point has to reach its limits ? Or does it reach its limit when pi can no longer push (basically reached its limit) ?
Default 07-01-2018, 09:26 PM
PI is in place to support the HPFP...
To my knowledge the "limit" of PI hasn't been reached, and various PI injector options too.
Car: 2008 E93
Default 07-01-2018, 10:49 PM
I understand that. Im just confused. Ive seen quite a few logs posted from hybrids to single turbos, and many have hpfp dips as do I. I saw a log on a single turbo that dipped on hpfp to 8s i believe and pi was flowing so much that his trims were 0 for the majority of the pull.
Default 07-02-2018, 07:51 AM
You don't want that to happen. I think that might have been my log that you are referring to where HPFP was around 6-8 but my PI was at 100% duty cycle. That is maxing out EVERYTHING and not safe. Best would be to lean the system out by adding some pump gas or bigger PI injectors.
Default 07-02-2018, 01:49 PM
Fuel pressures of 110psi won't be very advantageous as the LPFP flows will drop drastically at those pressures. As Payam said, you'll want to install an external regulator if flows are an issue. The stock one can bleed off flows and pressures. That pretty much goes for any regulator that is installed before the HPFP and/or port injection rail.
Snowman Snowman is offline
Car: BMW M135I
Default 07-02-2018, 01:50 PM
Isnt it possible to to do the same except have trims pegged at 0 since the PI are overfueling?
I had that on my first PI log and the PI sprayed to much fuel, causing the HPFP and DI to lean out as much as possible and the HPFP to basicly just "idle".
Car: 2008 E93
Default 07-02-2018, 10:20 PM
I wondered the same thing. If you turn pi all the way up, trims would crash and DME should pull fuel. It doesnt know there is pi so it would pull it from the hpfp causing it to drop in pressure in logs ?????
So it would show fuel starvation (depending on how low fuel pressure drops) , but in reality AFR would still be on target becasue of pi ?
Is this feasible ????
Default 07-03-2018, 08:53 AM
I haven't seen that case where hpfp has been pulled so far down that it would be considered dangerous.
Car: 2008 E93
Default 07-04-2018, 01:53 PM
But can PI have a reverse effect on HPFP ? As in too much fuel so DME pulls from HPFP thus lowering the numbers (pressure) , instead of maintaining and pi supplementing ?
Steve just posted on his CPI thread having the exact issue I have as well as others I have seen and talked to about.
Default 07-05-2018, 08:34 AM
I have never seen that happen to be honest.
