SPANKY's Avatar
SPANKY SPANKY is offline
Car: 2008 335i
Default how to test vacuum on a single turbo car - 06-19-2018, 03:37 PM
as title states,how would i do so on a top mount single turbo?before was able to test with stock turbos by boost solenoids.
E90 SEDAN '08
-SiNGLE TURBO AUTO TRANS*FSB G5 ISO*100%METH**FUEL iT!STAGE 2*ALPiNA FLASH-
-NGK PLUGS*BMS OCC*RB VALVE-
-E85 MHD FLASH-
Ancient8989's Avatar
Ancient8989 Ancient8989 is offline
Default 06-19-2018, 07:42 PM
Why would you need to test vacuum on a ST?
Default 06-20-2018, 07:03 AM
There should be no vacuum at the wastegates. Only way would be intake manifold if you need vacuum.
SPANKY's Avatar
Car: 2008 335i
Default 06-20-2018, 09:41 AM
Looking to test how much vacuum my car has for PCV.wanted to make sure my car isn't pulling too much or am pulling correct amount of vacuum.not sure if it's important for single turbo cars but hearing people having issues with either pulling too much vacuum or not enough so...
E90 SEDAN '08
-E85 MHD FLASH-
Default 06-20-2018, 10:34 AM
You'd check through the intake manifold to see how much vacuum you have.
Is your car smoking or burning oil quickly? If not, then you have nothing to worry about.
SPANKY's Avatar
Car: 2008 335i
Default 06-20-2018, 10:59 AM
No smoke or burning oil quickly.im running the bms occ vta since when I went to single turbo the rear intake with that air flow connection that connected is now just hanging doing nothing.is that air sensor important to get working for our cars?
E90 SEDAN '08
-E85 MHD FLASH-
badblackcoupe's Avatar
badblackcoupe badblackcoupe is offline
Car: 2007 335i e92
Default 06-22-2018, 01:12 AM
That thing can just be unplugged and thrown out, it wont even throw a code. I think it just heats up whatever passes through for emission purposes. I cant be quoted on that though
E92 On3 6266BB
VRSF 7.5 HD
xHP Stage 3
Wedge tuned on straight E85
