SPANKY's Avatar
SPANKY SPANKY is offline
Car: 2008 335i
Default Fuel Bias Question - 06-07-2018, 04:18 PM
Didn't want to derail someone else thread so made my own.Terry mentioned about adjustment fuel bias for trims/hpfp in a thread.does this apply to to single turbo running chargepipe meth.if so does the fua have to be set then play with the fuel bias?looking to learn the basic since you brought it up and haven't seen it posted in a setup thread.want to now what's a starting point then which way to go for hpfp/trims
E90 SEDAN '08
-SiNGLE TURBO AUTO TRANS*FSB G5 ISO*100%METH**FUEL iT!STAGE 2*ALPiNA FLASH-
-NGK PLUGS*BMS OCC*RB VALVE-
-E85 MHD FLASH-
Default 06-07-2018, 06:48 PM
Not following the question but no setting changes are needed to adjust fuel bias and generally no fuel bias adjustment is needed as the JB4 already manages it.
Values of 50 across the board for straight e85 on stock or hybrid turbos and 80 for single turbos are suggested.
SPANKY's Avatar
Car: 2008 335i
Default 06-07-2018, 07:45 PM
I'll make it easier.Heres my setup for car on single turbo,methanol,running e40 ethanol mix,Map 8.Guess i am more questioning the FUA & Fuel Bias & Duty Bias settings
E90 SEDAN '08
-E85 MHD FLASH-
Default 06-08-2018, 06:07 PM
Set FUA to 0, set fuel bias to 50 across the board. Then log and evaluate it!
SPANKY's Avatar
Car: 2008 335i
Default 06-08-2018, 09:03 PM
its been so long that didnt realize you moved the FUA 60 to WMI page.So should i enable the WMI PUMP PWM still apply?im running cm10 & cm07 nozzles
E90 SEDAN '08
-E85 MHD FLASH-
