g4z808 g4z808 is offline
Car: M235i
Default log read - 05-30-2018, 07:02 AM
Looking for a log read to check safety and any suggestions
2017 340i
MPPSK
JB4 w/ latest FW
BMS Intake
93 + 2gal E85
Map 5
Default 05-30-2018, 10:29 AM
Log is looking good with the fueling used. The trims are a bit on the high side, you can try setting open loop to 70 to see if that helps. You would really benefit from the EWG wires.
Car: M235i
Default 05-31-2018, 08:17 AM
I'll order the EWG wires. What will this do for me ?
Default 05-31-2018, 10:55 AM
EWG wires will help you boost higher on the map you're using.
