Car: N54 335i
Jb4 installed car acting up -
04-19-2018, 12:48 PM
Bought a jb4 on a different forum, installed it just as described online went to start the car and it idles horribly had like 12 codes on..removed the jb4 and the car was back to normal. Any ideas of cause or how to fix thi issue?
04-19-2018, 12:53 PM
Would need install photos, code listing, JB4 log, etc, to offer any advice.
Car: N54 335i
04-19-2018, 01:26 PM
New to all this is there anyinfo on how to send logs and code listings
Car: N54 335i
04-19-2018, 07:12 PM
180419_1907.csv
04-19-2018, 07:39 PM
That's not a log as there are no values. Update your firmware and post a log.
Car: N54 335i
04-19-2018, 07:41 PM
Sorry im new to all this havent even driven the car with the jb4 on it because it stalls out
04-19-2018, 07:42 PM
Looks like very old firmware. Install photos?
Car: N54 335i
04-19-2018, 07:46 PM
Sorry no photos i just took it off
Firmware ver 31//2
Interface ver 4/1/18
Car: N54 335i
04-21-2018, 10:32 AM
I updated the firmware and set it to default like the picture and still acts up
Car: N54 335i
04-21-2018, 10:39 AM
Originally Posted by Haynpunch
still acts up did as you said and get these codes :
3100 low boost mode engaged -- CEL displayed
2CF6 Throttle valve potentiometer 1, plausibility with regard to air mass
2D33 Absolute pressure sensor, intake pipe: Signal
2FBC Fuel pressure control valve, signal
2CF7 Throttle valve potentiometer 2, plausibility with regard to air mass
2D09 Drosselklappe
2E7C Bit serial data interface, signal
2A94 Crankshaft sensor, signal
2ACB DME digital motor electronics main relay, input signal
2CFB Throttle valve adaptation value
2ABC Charging pressure sensor, electrical
00F1 No Description Found
04-21-2018, 03:14 PM
Pictures of board, install, and a log please.
Car: N54 335i
04-21-2018, 07:40 PM
idk if i can do the log because i cant drive the car with the jb4?[ATTACH]  [/ATTACH]
Car: M135i
04-21-2018, 10:17 PM
This is the exact same fault I’m getting
2016 M135i - JB4, standard
Car: M135i
(From what you said)
I can’t get logs as I have no cable
Car: N54 335i
04-21-2018, 10:41 PM
Does your car have the same symptoms
04-22-2018, 11:11 AM
If installed properly, could be a bad board. You can purchase a replacement board at burgertuning.com
Car: N54 335i
04-22-2018, 12:10 PM
[ATTACH][ATTACH][ATTACH][ATTACH][ATTACH]  [/ATTACH][/ATTACH][/ATTACH][/ATTACH][/ATTACH]
heres the install pics i have the g5 iso 32 10 firmware....why is the water pump always on?
04-23-2018, 11:20 AM
Have you verified they are all properly seated at the DME?
I don't see anything obvious but when purchasing a used board and wiring harness, it's hard to say what the issue may be.
Car: N54 335i
04-23-2018, 12:28 PM
Everything was correct i guess its a bad board im getting my refund
04-23-2018, 08:57 PM
Thread Tools |
Display Modes |
