Car: BMW 135I
Changing Tranny Fluid -
02-03-2018, 03:36 PM
Question/ I have a 135I and it is time to change my transmission fluid.
Car -86,000 miles. What is the best fluid I can put.
1-Liqui Moly.
2-Red-Line
or stay with factory fluid.
I heard some people putting red line and transmission slipping.
Liqui Moly is used in the GTR cars , is very sticky to the clutches,
but I have not seen any reviews yet on the N54 tranny .Any suggestions.
BMS Customer Service
Car: bmw 335i
02-03-2018, 05:58 PM
I have tried redline once when doing valvebody upgrade.
I can't tell you if it was better then OEM or not as my AT started slipping at 620 wheel torque.
02-03-2018, 06:00 PM
I use Redline MTL. Not knowing what transmission you have complicates suggestions.
Car: BMW 135I
02-03-2018, 06:07 PM
i have At(Steprtonic) tranny , not manual or DCT
Car: 07 BMW 335i
02-03-2018, 07:48 PM
I used Pentosin. Has worked great so far, 20k with no issues.
02-08-2018, 09:33 AM
Use OEM only. I have used redline and trans started slipping. There should be some threads on here about this.
2008 135i Sport 6at
JB4 G5 ISO, MHD E85 KR, Fuel-it S1, E55 Mix, Alpina Trans Flash, afe Scoops, My own custom 2.5" inlets, ER CP, Synapse BOV, 3.5 Tmap, 7.5" Phoenix FMIC, NGK 5992, 3" BMS downtubes, N55 Mids, Berk Race, BMS OCC, 48 plate oil cooler, 36 plate trans fluid cooler, PSS, R888, Hoosier DRs.
11.92@123.6 (JB4 ISO, DCI, IC, **, DR, on e45 & 17psi)(2013)
444whp/481wtq @19psi and e60 (2013)
2013 X3 xDrive28i M-package
JB4, K&N drop-in, ER downtube, Map 2 @ 22psi on 93
Car: BMW 135I
02-08-2018, 01:37 PM
Ok thanks, I will keep my OEM .
Thread Tools |
Display Modes |
