Hi all,
I recently had some non optimal readings for low fuel pressure, while the high pressure reading was ok. ie first start up of day the LP showed below 10 and under load might go up to 30 and after warming up would go to 70. Mid day startup and it would be 65 and go to 75 under load.
So I replaced the fuel pump ( F90000267 ) .
Values are still low for the low pressure readings. High pressure readings range between 5 and 20.
I have a regulator that should arrive soon to swap. I hope this takes care of it, but I am wondering would temps affect the regulator this way?
Or is the low pressure fuel sensor? And if so, what is the part number for this? Real OEM shows on the N55 that it is no more?!
http://www.realoem.com/bmw/enUS/showparts?id=UN73-USA-10-2010-E88-BMW-135i&diagId=13_1355
Parts 6,7,8,16 are grey and not listed. with a feed line ( 17 PN 13537605020 ) that no longer has the sensor?!
I am finding two two low pressure fuel sensors that seem mostly interchangeable.
Sensor for low pressure (N55). Up To 09/2011 PN
13537614317 $89.67
Sensor for low pressure From 09/2011 Up To 03/2012 PN
13537622231 $133.03
Tech specs on the sensors to be able to test them would be ideal.
So my questions are,
1. what's the difference in the low pressure sensors. Is one more friendly with fuel additives like winter/summer blends with differing ethanol %s?
2. Is it more likely the sensor is out of whack because the HP reading is good, while 0 low pressure would not likely be able to create a high pressure reading of 15 - 20.
3. Or is it more likely that the regulator is in fact creating some real zonked out pressures?
