Wheats12's Avatar
Wheats12 Wheats12 is offline
Car: 2011 135i
Default Map 6 question - 10-09-2017, 01:21 PM
Running map 6 with no codes, plenty power
Very smooth..
Do these settings look good? Thanks
C]Pure stage 1, bms intake,bms chargpipe, jb4, flex fuel ,vrsf 7 inch intercooler, ******* bp ,custom m1 (quad) exhaust,1m front and rear bumper and VMR 710 wheels
Default 10-09-2017, 09:28 PM
Resize picture- can’t see anything
Wheats12's Avatar
Car: 2011 135i
Default Map 6 question - 10-10-2017, 12:42 PM
Hopefully this works
Default 10-10-2017, 07:39 PM
Poor log, please review the logging guidelines. If you plan on using map 6, you'll need to be able to take good logs and and be able to review them.
http://www.n54tech.com/forums/showpo...21&postcount=1
Wheats12's Avatar
Car: 2011 135i
Default 10-11-2017, 02:39 AM
Will do.. thanks
Wheats12's Avatar
Car: 2011 135i
Default Map 6 log - 10-11-2017, 11:57 AM
Here's 2 wot from about 2600 to 6400 rpm, dct fully off
3rd gear, no codes
Has 4 gal e85.. have the flex wires
Perfect timing to be next to m4 as I was keeping up with it
92 degrees, flat Florida highway..
Thanks for looking at it..��
Default 10-11-2017, 06:29 PM
Better...those look pretty clean.
Wheats12's Avatar
Car: 2011 135i
Default Map 6 log - 10-13-2017, 01:25 PM
Changed fol to 40..seems more responsive
How's log look?
What a blast to drive!
Thanks Steve
Default 10-14-2017, 11:26 AM
Wheats12's Avatar
Car: 2011 135i
Default 10-14-2017, 12:59 PM
Steve..
What would you think about it I increase psi by
1 and increase fol to 70? On map 6 of course
Wheats12's Avatar
Car: 2011 135i
Default Map 6 log - 10-15-2017, 07:45 AM
Here's a log that I increased psi by 1 on map 6 and bumped up for to 70
Just 93 oct
10 am. 86 degrees..
How's it look? Thanks
Default 10-15-2017, 09:00 AM
Some timing drops - doesn’t look as clean as prior
Wheats12's Avatar
Car: 2011 135i
Default 10-15-2017, 09:53 AM
Thanks Dave...
Would you suggest to drop psi .5 and fol some ? Then log again?
Thank
Wheats12's Avatar
Car: 2011 135i
Default Map 6 log - 10-15-2017, 11:32 AM
Here's a log of map 6 targeting max of 17 and 50 on fol..
Wicked fast while smooth..
No codes ..
Tell me what you think..
Thanks.. you guys are making this alot of fun
Default 10-15-2017, 03:58 PM
Not bad, looks pretty normal for an N55 with stock flash.
Wheats12's Avatar
Car: 2011 135i
Default Map 6 log - 10-15-2017, 04:23 PM
Sorry.. sent old log..
This is most recent.. map 6 maxing at 17 and 50 fol
Kinda new to this... but if this is just a normal stock flash
What's left? Other than pure stage 2
Default 10-15-2017, 10:25 PM
Stock turbo is only going to hold about 11psi up top.
Looks like the same log to me.
Wheats12's Avatar
Car: 2011 135i
Default Map 6 log - 10-16-2017, 12:56 PM
Steve... this is the newest log..
Thanks for looking... this is max 17 fol at 50..
Pure turbo stage 1 on only 93
Wheats12's Avatar
Car: 2011 135i
Default Map 6 log - 10-16-2017, 01:01 PM
Log
Default 10-16-2017, 10:56 PM
Pulling quite a bit of timing, I'd back off on the boost a bit.
Wheats12's Avatar
Car: 2011 135i
Default Map 6 log - 10-17-2017, 08:20 AM
A bit.. meaning. .5 psi reduction and re Log?
Also... noob question... what do I look for regarding a good timing Log?
Thanks!!
Default 10-17-2017, 08:07 PM
I'd try a psi or 2 and see how that looks.
Check out this thread for more info...
http://www.n54tech.com/forums/showthread.php?t=21269
Wheats12's Avatar
Car: 2011 135i
Default Map 6 log - 10-18-2017, 02:39 PM
I did a map 6 log for fun by copying another members pure stage 1 settings..
The boost and others parameters are higher I know, but wow it's very smooth and wicked fast..
Just running 93 and it's was 88 at time of log..
If you could take a look that would be awesome..
Looks like timing settled down somewhat
Thanks again
Default 10-18-2017, 04:16 PM
Timing Looks pretty horrid- I’d back way down on boost
Wheats12's Avatar
Car: 2011 135i
Default Map 6 log - 10-18-2017, 04:29 PM
Wow...
Ok.. thanks for checking it out..
