Narcosis's Avatar
Narcosis Narcosis is offline
The dude abides
Car: E92 xdrive
Default 3.5 bar tmap sensor - 07-28-2017, 02:18 PM
I'm using the N20 3.5 bar TMAP sensor, and am wondering if there will be an issue if I pull the JB4 out & leave the TMAP sensor in place. Will the DME see & flag it, or will I be in the clear?
Thanks.
Default 07-28-2017, 02:20 PM
Car will stumble and most likely turn off.
Default 07-28-2017, 07:19 PM
If you also leave tmap unplugged car will at least run just with no boost.
Narcosis's Avatar
The dude abides
Car: E92 xdrive
Default 07-29-2017, 09:39 AM
Thanks Payam & Terry.
as3.0cl as3.0cl is offline
Car: 335is
Default 08-05-2017, 06:57 AM
as a quick follow up on this, what if we set the JB4 to Map0? will the car still stumble and not run right?
I'm up to 19.5psi using the stock sensor, might want to push higher but need the sensor head room in boost reading. but every once in a while I have to bring the car in. Usually I take the BEF out and set the JB4 to 0. I would hate to also always have to pull the TMAP sensor in and out when it needs to go to the dealer for a small fix.
2011 335is - Alpine White on Red - JB4+Trebila BEF l BMS DCI l Mishimoto IC l BMS OCC l Phoenix CP l BWS WMI 100% CM5+CM10 l Turbosmart Plumb Backs l N54tech Dpipes
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 08-07-2017, 09:26 AM
In your first post you talk about removing the JB4 entirely, but in above you mention leaving it in and just setting to map 0 and removing BEF. Which are you talking about?
If you leave JB4 in and set to map 0, I'd trying leaving the 3.5 TMAP in. I think it might still use the TMAP setting 1 (N20) scaling, and allow the engine to run normally with a 3.5 bar, even if the other JB4 functions are turned off.
If you actually remove the JB4, you have to return TMAP to stock for engine to run normal.
Car: 335is
Default 08-07-2017, 11:33 AM
The OP was asking if he left the sensor in but pulled the JB4 completely out.
I am asking is can we leave the sensor , leave JB4 in but on Map 0? and in this situation, with the TMAP setting at 1 for the 3.5Bar, will the car run normally.
LessIsMore's Avatar
Inner Circle Member
Default 08-08-2017, 01:48 PM
Woops, mixed you two up - sorry
Not positive but I think so. Why not just put your car in map 0 and find out?
Car: 335is
Default 08-08-2017, 01:52 PM
np - I would try it, but i don't have a 3.5 TMAP yet.....
Debating on getting one since i'm at 19.5psi with the stock TMAP and deciding if i want to try to go a little higher or just leave it as is. Or get the 3.5 TMAP for safety reasons since i'm at the end of the rope with the stocker.
LessIsMore's Avatar
Inner Circle Member
Default 08-08-2017, 01:57 PM
You need the 3.5 bar. A small boost spike could overrun the stock sensor scaling.
if you have to go back to stock sensor for some reason, it's only like a 10 min job. I can get to my TMAP sensor just removing one clamp for the rear DCI filter.
Bigs135's Avatar
Bigs135 Bigs135 is offline
Default Tmap sensor - 01-06-2019, 11:44 AM
Is there anything you have to change in your user settings when upgrading to a 3.5bar Tmap Sensor?
Default 01-07-2019, 09:11 AM
Yes, need to change tmap value to 1.
Bigs135's Avatar
Default 3.5 bar map sensor - 01-07-2019, 05:17 PM
Thanks Payam! Ill let you know what happens next as this is being my first start up.
keninger keninger is offline
Car: 335i E92
Default 01-09-2019, 11:05 AM
I have also bought a 3.5 bar tmap sensor, I know I have to change the n20 tmap to 1 in user adjustment settings, but I have a custom BEF which was mapped for the stock sensor. If I reflash the tune in MHD and check n20, which will rescale the sensor values, and I also change the JB4 n20 tmap to 1 would the two interfere?
Because in map 0 the JB4 leaves everything up to the dme flash and goes into bypass, but the flash not knowing what to do with the n20 sensor, the car won’t run properly.
Once I install an n20 sensor I can only run with the JB4 on, or can the flash also be mapped for the n20 sensor?
Default 01-10-2019, 10:23 AM
Do not check the box for MHD for N20 sensor. Only on the JB4 side, even on map 0 it will work.
Car: 335i E92
Default 01-10-2019, 11:24 AM
Thank you! Now it is completely clear.
Default 01-10-2019, 09:05 PM
Common mistake. Sometimes if you do flash it for a 3.5bar on the MHD side, you have to flash back to Stage0 (stock) fully, for it to retake the setting change.
Car: 335i E92
Default 01-11-2019, 03:15 AM
Sometimes you have to flash back to Stage0 (stock) fully, for it to retake the setting change.
That is kind of weird, but yeah I haven't gone ahead and flashed it because I was suspecting something similar. Now I will install it and just set it up on the JB4 side. Thanks again.
