cmiggz's Avatar
cmiggz cmiggz is offline
Car: 2008 BMW 335i
Default Turbo Spool Up - 07-27-2017, 02:23 PM
Out of curiousity, has anyone with a single turbo conversion done or thought about putting a 50shot of NOS, to spool up the turbo then cut it off for 1/4mile?
Is it possible to do with jb4?
My best pass with stock turbos was a 11.7 @116 60" 1.7, now single turbo My best pass is 12.2 @125 60" 2.3 low boost with lag at take off.
Thanks for input.
Venom77's Avatar
Venom77 Venom77 is offline
Car: 335I
Default 07-27-2017, 05:32 PM
Launching a ST at the strip is crappy. I ran 12.2@128 with a 2.3 60ft when I was out last. Ive been practicing my launches and will be happy with a 2.0 60ft next time Im out.
To answer your question tho, I haven't seen anyone play with spray on a ST yet.
Garrett Gtw 6465, Supporting mods , Mhd/Jb4
Connormobley Connormobley is offline
Default 07-27-2017, 06:23 PM
Do either of you have a manual gear box?
FEDE/E92 FEDE/E92 is offline
Default 07-27-2017, 08:06 PM
Auto or MT?
cmiggz's Avatar
Car: 2008 BMW 335i
Default 07-27-2017, 08:34 PM
Im auto, just wanted to see if anyone was on spray. Iv seen other platforms do it,thought id ask.
limitdown's Avatar
Car: 2007 335i E93
Default 07-27-2017, 10:59 PM
Reminds me of Volvo's "PowerPulse" system. I wonder if that system ever proved to reduce lag. They use an air compressor to fill air in a small tank. When requested, air is shot into the turbine
Venom77's Avatar
Car: 335I
Default 07-28-2017, 01:05 AM
Im auto also.
defineste90 defineste90 is offline
Default 07-28-2017, 04:39 AM
i heard rumors of JTSWOLE runs some NOS on his ST but i cant confirm
CharliesN54's Avatar
CharliesN54 CharliesN54 is offline
Car: 2008 335xi
Default 07-28-2017, 06:49 AM
What kit are you running? What turbo? How much boost? E85? Meth? Are you having traction issues? IMHO you should be running faster than you are and NOS is just an added risk I personally wouldn't take.
Single Turbo Z4 that's constantly broken
bigdaddyaaron's Avatar
bigdaddyaaron bigdaddyaaron is offline
Default 07-28-2017, 07:40 AM
I'm MT. Right now, my best 60ft on a single turbo is 2.1. That was with preload.
Recently, I bought a wot box and a 3.46 diff. The wot box will build boost off the line and the 3.46 diff will get to a relatively high-load rpm faster. this is all theory, though. I'll be installing in the next month or so to test.
Default 07-28-2017, 12:46 PM
@bigdaddyaaron have you used the bms 2 step before?
Default 07-28-2017, 03:16 PM
I'm flash only
Default 07-28-2017, 04:30 PM
I'm flash only
cmiggz's Avatar
Car: 2008 BMW 335i
Default 07-28-2017, 05:05 PM
I have a jpworkz kit. 6266. 20psi, no traction issues and when i tried to spray meth it would go into limp mode guess it doesnt like going 1st-4th gear from a dig. I havent took it since. Im going to just do 1/2 miles now as 1/4 mile is no bueno
Default 07-28-2017, 06:40 PM
Your issue is obviously tune related. Where is your meth being sprayed?
Default 07-28-2017, 07:28 PM
defiantly tune related
