Q50RS400 Q50RS400 is offline
Car: 2017 Q50 Red Sport
Default Warranty with mods - 07-13-2017, 03:17 PM
Ok, so doing some reading in the bmw forums about the detectability of the jb4 even when removed when you take it to dealer. Seems to be a 50/50 answer as they say if you dig into the boost/fuel logs in the ecu you can tell that the car was tuned, some even had their warranties voided.
Is there a clear answer regarding detectability for the q50? Besides from removing the piggyback, is there anything else you need to do, such as clearing codes or whatever else? (read this in the bmw forums)
Does the burger tuning piggyback for the q50 report false fuel/boost readings to the ecu to trick it so it is not traceable?
The 3.0T Q50’s have had issues with snapped belts and blown motors – so I don’t want a common mechanical issue not be covered under warranty due to the tune.
Default 07-13-2017, 03:22 PM
We know a flash tune is completely and obviously detectable but I can't say for sure whether or not Stage1 is detectable on the platform once removed. I suspect it's not. That said don't make warranty claims on parts you've broken with aftermarket modifications.
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 07-13-2017, 03:31 PM
+1
Mods: Stock for now
Default Warranty with mods - 07-14-2017, 12:30 PM
no need to bring our your book of ethics here. You guys clearly highlight the fact on your product page that you can remove it without a trace when needed, ie, during dealer visits. Why else would somebody want to remove the tune??
as i mentioned, the 3.0T q50 have issues with throwing belts and blowing motors on STOCK cars, it is a common issue, which was my concern. I do not want my warranty voided from the tune on a common engine issue which is why I asked.
Regardless, on 91, the power to potential losing warranty risk is not worth it, so will not go with the tune.
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 07-14-2017, 03:12 PM
Don't worry about their ethics. Plenty of us mod and get stuff replaced under warranty. In the US dealers/manufacturers cannot void your warranty for mods unless they can prove that a mod is the direct cause of a problem. The Magnusson-Moss Warranty Act protects us from having to use stock parts on our cars unless the manufacturer gives them to us at no charge.
So go for it. Put on the Stage 1 and have fun.
Mike Levy
2021 Tanzanite Blue II M550i xDrive
2018 Silver Equinox LT 2.0T
Lowon's Avatar
Car: Bmw M2
Default 07-14-2017, 04:07 PM
100 true, unless your engine blows and you have a tune. In this situation it'd be very easy for the dealer to pin it on the fact that the motor wasn't designed for this added power and boost.
Again Mike is correct, if the mod isn't related to the part that goes wrong then it should be fine.
Personally I don't care about warranty when I mod (I either just tell the dealer and pay for damages myself and forfeit my warranty, or don't mod, but that's just me), because even if you find a "mod friendly" dealer and something major goes wrong (blown motor). I'm pretty sure they most likely won't warranty it because if corporate gets involved they could literally sue the dealer ship and the owner for warranty fraud and breach of contract. Then the owner of the dealer would probably sue the SA who authorized the warranty. So imo they probably wouldn't do it for you if it was an uncommon engine failure and they knew it was caused by mods.
Not here to tell people what to do, just being realistic.
Mods: Stock for now
Mike_L's Avatar
Anti-Social
Default 07-14-2017, 05:46 PM
Some manufacturers are more friendly. I got 4 transfer cases for my Jeep SRT8 replaced under warranty, despite having a full top end build. For whatever reason though, they wouldn't replace the transmission.
Audi is the absolute worst. They'll fight every step of the way.
Mike Levy
Lowon's Avatar
Car: Bmw M2
Default 07-14-2017, 07:37 PM
Yeah I've heard. Like Ford will manufacturer warranty roush parts like a supercharger on the V8 mustangs.
Never had too much experience with Audi asides my R8. But j supercharged it so I pretty much never even came in for service let alone warranty.
Mods: Stock for now
