Car: 2008 E93
Default Maps and boost targets - 07-13-2017, 10:17 AM
Does anyone have a link or can tell me what boost targets are for n54. Specifically, is it the flash for say a single turbo, or hybrid flash that targets higher? How are some running map 2 at 22 psi ? What are map 3 targets if you have a 3.5 bar and hybrid flash ??? I know depends on add, but is there a chart for all this somewhere ? Im only interested in upgraded and single turbo conversions. I am aware of the stock turbo maps and targets. Thanks
Default 07-13-2017, 05:10 PM
It varies by application.. But best best is to ask in the appropriate thread. Single turbo thread, BEF thread, straight JB4 thread, etc.
Lamar Vannoy Lamar Vannoy is offline
Car: 135i N54
Default 07-17-2017, 08:24 AM
I think it would be helpful if there was a table of map vs BEF type or even better RPM vs Boost for each flash/map like there is for the map3 boost additive. Unless the BEF changes the map3 targets, then that's useless.
Car: 135i N54
Default 07-31-2017, 10:56 AM
I logged map2 on the pump BEF peaking a 18.8 lbs this weekend
Default 07-31-2017, 03:31 PM
The map target line will be clearly visible in your log. As will boost. If boost and target are greatly apart then dutybias tuning is normally needed.
