yak52 yak52 is offline
Default In-Dash MHD? - 05-19-2017, 09:39 AM
Just discovered the world of in-dash Android head units. Hit me that MHD runs on Android and eliminating the tablet would be nice. Is there any way to run MHD on one of these?
Anyone have an in-dash system similar that can test to see if MHD runs? Would be sick if it worked and gauges came up on the in-dash unit. Did some searches and came up empty. Sorry if it's been discussed previously.
https://www.youtube.com/watch?v=USBXXLUwfzs
2007 335xi 6MT, Hexon Stage 1+ Hybrids, Hexon Inlets, Injen Intake, RB PCV Valve, ETS 7" intercooler, HKS SSQV, ETS Charge Pipe, DP's, ACT SM Flywheel, 335is clutch
NoGuru's Avatar
NoGuru NoGuru is offline
Car: 2011 335is
Default 05-19-2017, 12:13 PM
I am curious about this as well.
HanSolo71 HanSolo71 is offline
Car: 2008 135i 'Vert M-Sport
Default 05-19-2017, 12:26 PM
Same.
08_335i 08_335i is offline
Car: 2008 335i
Default 05-19-2017, 01:21 PM
The Eonon GA6165 is a popular choice.
fredcase fredcase is offline
Car: 07 335xi
Default 05-19-2017, 03:22 PM
Link?
I would love to set this up with the jb4 app.
2007 335i MT, JB4 G5, Hybrid Race BEF, DCI, Inlets, RB 2ís, outlets, 6" AMS FMIC,Chargepipe with Raceport BOV, d_p's, stage 2 lpfp, Mfactory LSD, X-Clutch twin disk.
Default 05-19-2017, 05:44 PM
Any for a 135i without the idrive?
BevsM3's Avatar
BevsM3 BevsM3 is offline
Car: 2010 535i m sport wagon
Default 05-19-2017, 05:53 PM
Wouldn't it still have to tap into the OBD??
1and1 1and1 is offline
Car: '09 135i
Default 05-19-2017, 06:21 PM
Yes, preferably by cable for good logging or, especially, if you plan to flash maps.
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla
. . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's
X1 - E84.N20 2013 MGM - JB4 - The Wife's
Jeffman's Avatar
Jeffman Jeffman is offline
Default 05-19-2017, 07:11 PM
Of course. But I hear MHD is developing a Bluetooth connection.
2008 E90 335xi AT 67K MILES
MHD CUSTOM FLEXFUEL 24 PSI, N20 TMAP, FUEL-IT STG 2 LPFP, cPE CHARGE PIPE, HELIX IC, TIAL Q BOV WHITE SPRING, BMS DCI, BMS T-STAT DELETE, BMS HIGH AND MISHIMOTO LOW OCC, RB PCV, KW-V1 COILOVERS, APEX ARC-8, 235/265 MICHELIN PSS, xHP STAGE 3, SCOOPS, PR IGNITION
JLIT's Avatar
JLIT JLIT is offline
Car: BMW 335i
Default 05-20-2017, 01:16 AM
I just got the Eonon 7165 and plan to install into my 08' 335i without Logic 7. Not going to do a video but I'll take some before and after pictures
E90 - 2008 -335i - FBO: WedgePerformance Tune, xHP Stage 2, Inlets, BMS DCI, 7" FMIC, ER CP w/BOV, VRSF meow-less DP w/lower cp upgrade, Vanguard full catback exhaust, KW V2 Coilovers, rear diff strut brace. Wheels stock af.
Default 05-22-2017, 01:15 PM
Found out I have the Logic 7 system. Looks like some people have moved L7 HU to trunk to install aftermarket, but sounded pretty involved. Guess there's a fiber optic cable to run amps, and aftermarket would involve replacing factory amps, running cables to trunk, etc. I like the sound now, but the MHD/JB4 in dash could be slick, in addition to all the other features these Eonon etc brands offer.
Anyone have input on aftermarket w/ Logic 7? Done a lot of searching, and I'm probably going to give up on the idea unless someone says it's not that bad.
Thanks in advance.
Jeffman's Avatar
Default 05-22-2017, 05:48 PM
Instead of an Android head unit, have you considered a video switching unit like Xcarlink that connects other Video units to the iDrive display? You can then run an Android mini computer / TV Stick into it such as described on this other website: https://bmw.***********.com/threads/...65/#post-13741
Glinx Glinx is offline
Car: 2009 E92 335 and 2002 E46 Touring
Default 12-05-2017, 10:49 PM
So has anyone tried running MHD on an Android head unit?
Car: 2010 135i
Default 12-06-2017, 02:17 AM
Yes. It works, logging and such. I haven't had the gumption to try and flash yet.
2010 135i auto,
NoQuarter NoQuarter is offline
Car: 2008 535xi
Default 12-06-2017, 06:38 AM
Something to watch out for.... I powered my Android device from the power that goes to the iDrive screen. Big dummy.... During a flash the iDrive screen loses power.
Once I switch it to a better power source then flashing it won't be a problem.
I currently have a wireless mouse in my center storage console but plan to add a touch screen overlay to the iDrive screen.
Default 12-06-2017, 07:51 AM
What head unit are you using and did you just plug the Dcan cable directly to the unit or did you have to make any mods. Does the MHD app ( gages, logging, etc) run pretty good? Thanks
Default 12-06-2017, 08:07 AM
Very nicely done. I don't have iDrive and currently using a old Note 5 phone. I'm just getting tired of having to manually power it on, going through the lock screen each time, and having to disconnect and recharge every other day. I wanna be able to get in start the car and go.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 12-06-2017, 09:31 AM
This is not as expensive as I would have thought, if it's a plug an play solution:
http://www.dvdgpsnav.com/catalogsearch/result/?q=bmw
Has solutions for a lot of BMW models.
Car: 2010 135i
Default 12-06-2017, 12:11 PM
I bought this one,
http://xtrons.com/pb7681bap-7-hd-dig...-1-series.html
There is a wire harness to for a USB that plugs into the deck. Then just plugged my cable in and it worked. Seems faster than through my phone.
The one thing I notice though is it gets really hot and slows down. There is virtually no air movement so that is my next goal.
And right now I'm having an issue with the radio 'optimizing apps' continually. Waiting on a response for what to do about that.
Sounds like it's something on my end/fault.
Also, I bought mine through Amazon because shipped it was the lowest price I could find. Easier returns and such also. Was sold through Xtrons though.
*edit 12/08/2017
My radio is back up and running. Took a factory reset to remove a corrupt app. Works fine now.
2010 135i auto,
