uncleivenm135i's Avatar
uncleivenm135i uncleivenm135i is offline
Car: M135i
Default 2016 M135i Logs - 04-21-2017, 08:22 AM
Hello chaps
Thought I would try and capture some logs after running with the JB4 for 24hrs.
Apologies if I haven't done this correctly, I changed between Map 1 and 2 so not sure if it needs time to adjust properly.
I'd be grateful if one of the experts could cast an eye over the attached
Cheers
Adam
2016 M135i - JB4, standard
Default 04-21-2017, 12:33 PM
Looks pretty normal, traction control turned off?
Car: M135i
Default 04-22-2017, 02:12 AM
Yes it was mate
So how's it looking re Map 2 or do I need to get more data?
Default 04-23-2017, 10:32 PM
It looks fine thus far.
Car: M135i
Default 04-24-2017, 01:08 AM
Thanks Steve
Car: M135i
Default 05-08-2017, 05:57 AM
I've captured a few logs after running with Map 5 for several weeks, I would be grateful if you can take a look for me
It certainly feels like it's making a big difference once I have done a few WOT to get the map running at it's full potential.
I have a rolling road session tomorrow, so want to see if I am best to compare between Map 0 and Map 5 or Map 0 and Map 2 (based on my previous logs earlier in the thread).
Adam
Default 05-08-2017, 09:31 PM
Are you running EWG wires? Doesn't appear as though you are and I'd recommend adding those if you're looking to hit your boost targets on map 5.
Car: M135i
Default 05-09-2017, 12:33 AM
Nope I'm not using the EWG wires.
So what would you think is possible in terms of boost compared to what I'm getting now?
Can you shed any light on the logs as they are as I still don't really understand what I am looking for/at :-p
Default 05-09-2017, 11:19 AM
You need to install the EWG wires if you want to run more boost or hit boost targets on on non-additive maps.
