Strangest N54 I've ever come across -
12-08-2016, 02:09 PM
H O O N
Car: Ein M
12-08-2016, 02:18 PM
Neat! MAP sensor, O2 sensor, and TB vacuum port?
Haha was wondering what they did with the O2s when the first pic popped up on IG.
Car: 2010 535i
12-08-2016, 02:32 PM
Clean. I wonder if an N54 would fit in the Gozer.
12-08-2016, 02:40 PM
Ha! That's neat!
-O2's not per bank and a mile away from the motor
-CP coupler is going to pop off
-Pos lug on the alternator should be capped
-Tmap is hanging out in the engine bay!
12-08-2016, 03:35 PM
I remember before I joined BMS Me and Anthony were supposed to work on it. He never brought it to us though. Glad its actually working!!
12-08-2016, 03:41 PM
Originally Posted by Pure Turbos
Ha! That's neat!
Haha yes the three obvious problems I was talking about was the o2 sensors being so far downstream, not seperated by bank, and the TMAP sensor not mounted in the chargepipe. But the chargepipe does look loose and there are various other minor things. Another problem we ran in today was there is no OBDII port.
12-08-2016, 04:02 PM
This is absolutely insane. Thanks for sharing.
12-08-2016, 04:49 PM
Oh, ya. He's going to need one of those...
Car: 2007 BMW 335i E92
12-08-2016, 10:35 PM
Nice!  )
Terry, please share if single bank O2 issue will be solved
Lol, i wonder how they change spark plug on sixth cylinder
2007 E92 335
ST - GTW3684
MT (after swap),
MFactory LSD
Car: 2008 535xiT e61
12-08-2016, 10:48 PM
1. Throttle body connector is unpugged
2. Charge pipe needs map sensor bung tapped into it
3. No throttle body bypass air hose
Sick project! I'm so happy to see the n54 being swapped into different chassis
2008 e61 535xit: VTT GCs, Fuel-it PI, fuelab FPR w/ return line, stage 2 lpfp, fuelab "700" inline pump, RB external PCV, VRSF 7.5" race FMIC, Inlets, outlet, AR ***, 3" chargepiping, 3" exhaust, JB4, BMS PI controller
Car: 335i xdrive
12-09-2016, 08:22 AM
All that work and no standalone EMS?
Car: 07 E92 335i
12-09-2016, 08:32 AM
Originally Posted by Levan-i
Nice!  )
That is a great point
2007 E92 335i 6MT
New Jersey
N54-Tuning 3'' Downp!pes, Vrsf 5'' Intercooler, Vrsf Charge Pipe, Tial-Q BOV, Vrsf Lower Charge Pipe, Act HDSD Clutch, JB4 G5 ISO, BMS Intakes, Custom Axle Back w/ 3" Tips
Car: Anything with a Turbo
12-09-2016, 01:29 PM
Pretty clean for what it is. Needs a lot more than tuning help thats for sure. Shouldn't it be a requirement, that the person performing the engine swap at least know a little bit about the motor he is swapping in? Good luck with that one, looks like a can of worms to get working properly.
12-10-2016, 10:37 AM
Whoever made the turbo manifold and pipe did a nice job but missed some basic steps in terms of the O2 placement and such. Don't think they knew much about N54s in particular though. Also wish they would have gone with a PTE compressor. But at the end of the day even with 600whp or whatever this car will be stupid fast.
Car: BMW E90 335XI
12-10-2016, 03:04 PM
Shocked
Do more with less !
Car: 2007 e60 5 series
12-11-2016, 07:55 AM
Now I know I can do my n54 swap! Terry, does that even run? Doesn't that need a n54 ecu,or standalone to run the direct injection?? Insane piece! Keep us updated with the progress!
12-12-2016, 04:51 PM
Yes seems to run normally using a factory DME and harness they cut up a bit. They also put in the gateway and E series N54 dash modules. The fuel gauge doesn't work and the DME throws like 20 faults for various missing things it would normally have out on the CANbus like stability control, SRS, etc, but car runs and drives fine as far as I can tell. Once the o2 sensors and TMAP are sorted we'll see if it makes any power.
Car: M235i
12-12-2016, 06:53 PM
Very cool, must've been fun getting that up the driveway.
Car: 2008 E93
12-12-2016, 10:56 PM
Can you share drivetrain set up ? What tranny, driveshaft, rearend, gear ratio, and rear suspension set up plz.
Thread Tools |
Display Modes |
