FreemanPerformance's Avatar
FreemanPerformance FreemanPerformance is offline
Car: 08 E92 335i 6MT
Default Custom 3.5in single turbo exhaust - 10-30-2016, 09:37 PM
Thought I would post some pictures up of my setup to give ideas to other prospective single turbo guys.
Pretty simple 3.5in with one resonator
The car is loud and sounds alot like a supra. Virtually zero drone in 6th on the freeway.
The exhaust burble sounds extremely gnarly.
This was exactly what I was going for and had it all done for well under a grand.
Before everyone expresses their dislike with the single exit know that I do not care
08 e92 335i 6MT 43kmiles
JPworkz PTE6766
Fuel-It PI + stage 4 LPFP
VRSF 7in IC
JB4/MHD
Motiv twin disk ST clutch
Instagram: @freemaniac38
Venom77's Avatar
Venom77 Venom77 is offline
Car: 335I
Default 10-31-2016, 12:23 AM
Oh how I dislike single exits. lol
I do understand how much better they can be tho. I bet that thing sounds sick. Looks like its fabbed well.
Need a sound Vid btw
Garrett Gtw 6465, Supporting mods , Mhd/Jb4
FRNTHVY's Avatar
FRNTHVY FRNTHVY is offline
Car: AW135/E30M3 Junglegym
Default 10-31-2016, 07:11 AM
Looks good! Jake does great work.
snelson3003's Avatar
snelson3003 snelson3003 is offline
Car: 135I
Default 10-31-2016, 09:11 AM
Looks GREAT!
Single exit exhausts look odd but the performance on a ST setup should be greater than the stock setup by leaps and bounds.
Sound clip/video?
498WHP / 516TQ : 10/29/16
VTT Stage 1 + Billet Wheel | VTT Inlets | VTT PCV Valve | JB4 G5 ISO | BMS E85 Flash | Fuel It Stage 2 | ECS TwinTake| Stett Vacuum Canisters | Hartge Stepped FMIC | VRSF DP | 91Oct w/E50 | BMS Cowl Filters | Located in Denver, Colorado - High Altitude!
Maintenance: EKPM3-DE @ 74K | Water pump & T-stat @ 70K | Valve Cover @ 50K | VTT Turbo @ 70K | HPFP @ 65K | Walnut Blasting @ 65K | 6 Injectors @ 55K | Vacuum lines @ 55K | Spark Plugs @ 75K | Boost Solenoid @ 65K
Default 10-31-2016, 09:14 AM
Similar to our 135i single turbo exhaust. Good way to go!
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 10-31-2016, 11:14 AM
Nice! Have you considered swapping the rear bumper for the 328 one?
Default 10-31-2016, 03:34 PM
I have not considered it, it doesn't bother me enough to change it.
I have a new project in itself and that's traction. Already converted the rear brakes, some weld RTS and M/Ts will be mounted soon.
I will attempt to capture the sound but i dont think it will go well
JPworkz PTE6766
VRSF 7in IC
JB4/MHD
bigdaddyaaron's Avatar
bigdaddyaaron bigdaddyaaron is offline
Default 10-31-2016, 04:09 PM
please please please please please when you take a vid:
-DO NOT PUT THE PHONE/CAMERA/MICROPHONE 2 FEET AWAY FROM THE EXHAUST AND SIMPLY REV.
-DO NOT ATTACH A GO PRO TO YOUR REAR BUMPER (unless you just want to show flames)
The recipe for a useful exhaust vid is:
-a take off clip and/or a flyby clip
-an in-car clip (optional)
N54QC N54QC is offline
Car: 07 BMW 335i
Default 10-31-2016, 05:04 PM
Did you consider doing a Y-pipe so it looks cosmetically pleasing on the other side of the bumper? I would definitely do that before ever swapping bumpers.
Sered's Avatar
Sered Sered is offline
Car: 10/06 E92 335i
Default 11-01-2016, 04:01 AM
Very similar to my setup except I went with 4" and added a flex section. Also I have an aluminum race muffler instead of a resonator on a 328i bumper
2008 E90 6MT sports package, VM 6466g2, BMS PI, Fuel-It Stage 3+, JB4+MHD
2009 E89 Z4 DCT, JB4, MHD flash, DCI
Blaizon Blaizon is offline
Car: 2008 E92
Default 11-02-2016, 10:24 AM
Are you able to put the rear bracing in, or was that not a concern for you?
2008 Sparking Graphite 335i 6MT Coupe - JB4/FFTEC
2007 Montego Blue 335i 6AT Sedan
Default 11-02-2016, 12:27 PM
I could have made the rear brace fit but i havnt tried it on yet.
Here is a little video racing a H/C corvette, not a great showcase of the exhaust but you can atleast hear it spool. Gave him a few second hit and then embarrassed him.
https://youtu.be/a24BPvZq4PQ
JPworkz PTE6766
VRSF 7in IC
JB4/MHD
07tundra's Avatar
07tundra 07tundra is offline
Car: a slow one
Default exhaust - 11-06-2016, 11:14 AM
So how about making some extra exhaust systems and selling them? looks clean and sounds pretty good
Default 11-06-2016, 12:43 PM
This exhaust was fabbed by Jake @ Rawspeed
https://www.facebook.com/Rawspeedfab/
JPworkz PTE6766
VRSF 7in IC
JB4/MHD
Mikey William's Avatar
Mikey William Mikey William is offline
Default 11-06-2016, 05:20 PM
any clips of some fly-bys?
