30be code -
09-20-2016, 01:39 PM
as title say i got a 30be code, car runs normal besides on cold start up. is this a bad injector or? nothing really has change in my set up besides replacing my dme. could this be the issue?
Jb4 g5 , bms dci, er fmic , active d.ps , bms charge pipe, tial bov -2008 335i
09-20-2016, 01:40 PM
i will post logs when i get home.
09-20-2016, 03:06 PM
Here's a quick one , any advice?
09-20-2016, 03:15 PM
On cold start ups if i go slow like 1500-2000 rpms then come to a stop smoke pours out of the tailpipes. But only sometimes and when the car is cold any ideas if these two syptoms have somthing to do with each other?
09-21-2016, 05:35 AM
What's the description of the code.
FOL is set too high, lower it to 90 and I would recommend doing a backend flash.
09-21-2016, 10:23 AM
INJECTOR PLAUSIBILITY CALIBRATION
09-21-2016, 02:44 PM
Set fol to 90 , look any better?
Was also getting a misfire cylinder 1 , but it went away now?? Idk this car is making me nutz
09-21-2016, 03:42 PM
I'm thinking leaking injector , pulled the plugs cylinder 1 is sorted up more then others
Sooted *
09-22-2016, 09:46 AM
Looks okay for the most part. IAT's are a little high, so that may be why you pulled timing on cylinders 1 and 5.
On cylinder one, it's possible that it is a leaky injector. You'd need to test it.
09-22-2016, 10:15 AM
how do i test it ? something i can do? or take to shop?
09-22-2016, 10:44 AM
Check for wet plug, swap injectors....
09-22-2016, 04:15 PM
Ok yea i know its basic troubleshooting just making sure that's what you were referring to
09-23-2016, 06:39 AM
09-23-2016, 03:27 PM
So car seems to run fine now would a bad injector go away like that? Havnt had time to trouble shoot
09-24-2016, 10:33 AM
Here's cylinder 1 spark plug
09-24-2016, 11:03 AM
Picture will need to be under 200K to show up.
09-24-2016, 11:22 AM
Shoot i dont think i can trim them on my phone
Steve want me to email it to you
09-26-2016, 10:13 AM
No need as long as the car is running good but you can if you want.
09-26-2016, 02:52 PM
Still getting the 30be code injector calibration
09-28-2016, 03:21 PM
Sent 1 did you get it? What's the email so I can make sure i got it
09-29-2016, 09:07 AM
If you have an injector calibration issue, there isn't much we can do for you. I'd suggest taking it to a qualified mechanic.
Car: 09 335xi
10-11-2017, 05:01 PM
Did you figure this out?? I just recently did my injectors and they are all calibrated properly. I triple checked to make sure and I am getting this code.
@e9xjake 09 E90 335xi 6MT
JB4|BMS BEF|Doc Race w/PTE6266|VRSF CP w/Tial BOV|VRSF 7" IC|Fuel It! Stage 2 Bucketless|E40|
Thread Tools |
Display Modes |
