Car: 2011 335i
E85 Fuel Percentage -
09-15-2016, 04:21 PM
Hi everyone,
I just installed the FF wires for my N55 335i and I want to know how to mix E85. If I wanted to do 30% of my total 16.1 gallon tank is it as easy as adding 5 gallons of e85? Or is there some sort of math equation I have to do?? I don't wanna mess up my car so I've been holding off on this.
Many Thanks,
Kenneth
09-15-2016, 04:45 PM
You must have been bad at fractions and you also answered your own question, but:
5/16 * .85 = E26.5
Unless your pump gas has 10% in it then add:
11/16*.10 = E6.87
= ~ 33%
If you are lazy:
https://www.intercepteft.com/calc.html
Car: 2011 e92 335i
Use this.
http://www.intercepteft.com/calc.html
It is best to start low with your mixtures, log, then up the mixture. Depending on the amount of boost you are running you should be able to get away with E30-40 on the stock fuel system. I would start with E20 and log first.
Registered Users
Car: 14' F25 X3 xDrive28 M-Sport AlpineWhite DHP
09-15-2016, 08:33 PM
Originally Posted by Bimmer_Boost
Use this.
+1
Car: 2011 335i
09-21-2016, 09:35 AM
Thanks guys for the reply I went ahead and used the calculator but I'm confused. I used the two different calculators and got different results. Here check out the pic
Car: 2011 e92 335i
09-21-2016, 09:37 AM
I only use the lower calculator.
Car: 2011 335i
09-21-2016, 09:42 AM
Okay yea the lower one is straight forward and is how I imagined it being...the top one is like wtf? I live in california how do I know if my 91 has 10% ethanol though??? Do I ask the guy inside...either way it looks like the safe zone is 5-6 gallons of e85 then the rest 91. I won't nit pick exactly e30 since the JB4 auto detects.
Car: 2011 e92 335i
09-21-2016, 09:52 AM
I think someone from California will have to chime in. I know in Oregon every pump has E10 unless stated otherwise.
Car: 2011 335i
09-21-2016, 10:35 AM
okay yea doing some research and california doesn't have to state if it has ethanol in its pump gas lol ****ing cali
Anti-Social
Car: 2021 M550i xDrive
09-21-2016, 10:46 AM
I only use the top calculator. And I'm pretty sure that all pump gas in the US is E10 unless its for marine or aero use.
Mike Levy
2021 Tanzanite Blue II M550i xDrive
2018 Silver Equinox LT 2.0T
Car: 2011 e92 335i
09-21-2016, 10:52 AM
"Under the Renewable Fuels Standard passed in 2007, the Federal government requires certain volumes of ethanol to be blended into the U.S. transportation fuel supply.
However, states have discretion as to how much (or how little) ethanol goes into fuels sold within their borders.
And it turns out that relatively few states are doing much to encourage the sale of greater amounts of ethanol."
Registered Users
09-21-2016, 12:38 PM
I agree with Bimmer_Boost I use the lower one too , the other one you forgot to input the 10% of Ethanol in your gas tank prior
Car: 2013 335i
09-22-2016, 10:54 AM
Have you considered getting an ethanol sensor and analyzer from Fuel-It?
http://www.fuel-it.biz/ethanol-analyzer-options/
2013 335i F30 N55 PWG | JB4 + MHD BEF + xHP Stg3 | Pure Stage 2 + FBO | BMS PI controller + Meth | Fuel-It! Stg2 LPFP
Car: 2011 335xi
09-22-2016, 12:45 PM
In the first calculator you forgot to put the 11.1 gallons of E10 in there. That is why they are different.
09-23-2016, 03:02 AM
I will start trying using Sunoco E85 soon ...
15 BMW M4 Full Weoght 10.69@133mph stock turbos SOLD
18 BMW XXXX Car in Process
09-29-2016, 08:48 AM
Originally Posted by suchtragedy
This is a really cool product, especially for 150.
To the OP, just to confuse you further and prove why I would buy a sensor like above-
1) Regular fuel can contain up to 10%, but doesn't have to. It could be 0. Their call.
2) Fuel blends will vary based on if it is a summer or winter blend. Yes, there are different blends. Summer is cleaner burning and more expensive.
3) e85? ha ha try, e50-e90 at most places depending on what is most economical for them to provide at the time. You never know exactly what it will be at most stations.
Anti-Social
09-29-2016, 09:24 AM
1. Pump gas in the US is required to have 10% ethanol.
3. Anything labeled E85 is required to be at least E70 (which it is in winter).
Mike Levy
Car: E92 LCI 335i M-Sport Coupe
09-29-2016, 01:35 PM
Question regarding point 3....
I am now seeing the E85 label with a "Minimum 51%" logo as subtext. I cannot seem to find good information on the federal requirements for this fuel class including any relevant "octane" data. Do you have any knowledge on that front?
2012 E92 335i LCI M-Sport Coupe - N55/AT
JB4 ISO 5.11 | BMS Meth (50/50) | VRSF DP | VRSF CP | ETS 7" FMIC | BMS Intake | Fuel-It S2 | NGK @ 0.022 | E30 Fuel Blend | Alpina B3
Anti-Social
09-29-2016, 01:47 PM
I've never seen that. Is it marked as E51? Proper E85 is 105 octane AKI.
Mike Levy
Car: 2011 e92 335i
09-29-2016, 02:10 PM
This is what Steve got from the pump.
Anti-Social
09-29-2016, 02:38 PM
If the pump said E85 and I got E57, I wouldn't be calling Torco, I'd be calling the company who's station it was and then the Feds.
Mike Levy
09-29-2016, 03:22 PM
The Sunoco I use here says minimum 70%. If I were to ever get a reading below that Id be like Mike and calling the Feds.
So far the lowest it has been when I checked was 78. 90% of the time its spot on 85.
I need fuel tomorrow so I'll be sure to snap a pic and post it up.
Registered Users
09-30-2016, 05:57 AM
THey meant to say to call Torco for E98 meaning PURE lol.
And yes although pump says E85 minimum E70, there's been showing lately E70 even in the summer aka Gulf stations are known for this. This is why a lot of people have to test before pumping now.
As of late, September I've tested E80 at all long island stations and E85-E88 in NJ. I've already filled up 13gals of jugs when i see the content is e85 or higher
Hopefully they vary cuz thats what it seems to be, go back to our Valero and test it before.
Car: 08 335xi
09-30-2016, 06:36 AM
There is also this app that I made for mobile that works pretty good
E85 Calculator for Mobile Android iPhone
11.762 @ 118.40 (335xi Stock Turbo WR)(Totalled)
09 335i xDrive Stock (Sold)
12 GT-R BE 800 awhp 9.8 @ 139
Thread Tools |
Display Modes |
