08335ibmw 08335ibmw is offline
Default New dme new battery now what?? Need the pros - 08-16-2016, 06:26 PM
Ok so ive had a dme issue could not fix. Most of you prob read my thread on my consistent 2abc code. Long story short got new dme from rpm . Had to get a battery from car being down for month or 2. Got everything in and now i have long crank and no start. Cranks seem strong if that helps? And i cant connect to my jb4 app. Says cannot find it. Help please its been months im jonesen for the bmw back in action
Jb4 g5 , bms dci, er fmic , active d.ps , bms charge pipe, tial bov -2008 335i
Default 08-16-2016, 06:56 PM
Never problem solved all codes gone so far no 2abc or anything . But my fan is stayin on non stop . Normal? Never did that before
E90M335i E90M335i is offline
Default 08-16-2016, 08:47 PM
Go to menu 6-2 on the dash and see if that turns it off. If not then you water pump might need replacing..
2009 335i Msport stock turbos. Mods: jb4/mhd Race flash , bms intake, vrsf charge pipe, Rb pcv valve, AA *****ss *********, muffler delete, Bms meth kit.
Best 1/4 mile is 12.3 @113mph with 93Oct and meth add at 55 on map3 .
