3100 code and 2abc code -
07-21-2016, 07:51 PM
So just had the dme fixed for the 30bb now i have gotten new coils .. all misfires gone but have two codes that,wont clear 3100 and 2abc charge pipe sensor . Any advice?
Jb4 g5 , bms dci, er fmic , active d.ps , bms charge pipe, tial bov -2008 335i
07-22-2016, 06:41 AM
3100 is a result of the 2abc. That can be due to...
-Bad TMAP
-Bad wiring harness
-Dirty connector
-Wrong TMAP setting in JB4
-Wrong flash
07-22-2016, 11:26 AM
-Bad TMAP
-Bad wiring harness
-Dirty connector
-Wrong flash
ILL CHECK THE JB4 SETTINGS, I HAVNT CHANGED NOTHING WITH JB4 BUT DEALER DID TAKE IT OUT OF THE CAR SO MIGHT HAVE MESSED SOMETHING UP
07-22-2016, 02:20 PM
Here a log prob wont help much
07-23-2016, 08:48 AM
Here are my user adjustments
Car: 2007 335i
07-23-2016, 09:53 AM
Can't see user screen. Make sure tmap on charge pipe in in and connected proper. Then if you are using a bef, reflash it. Then update your jb4 firmware. Then follow all default settings.
2007 335i 4dr JB4, Hexon RR600, Inlets, 4Bar, Index 12, Boost Concept Pump, DCI, FMIC, DP and full exhaust, Burger Meth, MHD BEF. Auto.
Car: 2007 335i
Dealer likely flashed it.
07-23-2016, 09:59 AM
The tmap sensor seems like its in good and tight, i only have the jb4 app not a laptop
Car: 2007 335i
07-23-2016, 10:01 AM
Are you saying no bef?
07-23-2016, 10:02 AM
Try posting the picture again
Yea i do not have a bef
Car: 2007 335i
07-23-2016, 10:06 AM
If jb4 was uninstalled, you need to go through that. Make sure everything correct. I don't recall if that older firmware has a menu 4 setting for bef vs no bef
07-23-2016, 10:10 AM
The dealer took the j 4 out and i was having the issue with the jb4 iut as well as in
07-23-2016, 10:17 AM
Can you update firmware thru jb4 mobile? Or you need laptop and cable
Car: 2007 335i
07-23-2016, 11:40 AM
Through app.
07-23-2016, 03:58 PM
Yea i just tried to update firmware , it timed out now the car will start but dies a few seconds later .. ugh lol
07-23-2016, 04:03 PM
What to do now??
07-24-2016, 08:51 AM
Fixed that issue , i just ordered a new sensor mabey they hit it doing the other mods they were put on idk ill post the results
07-26-2016, 05:25 PM
Just replaced the tmap to no avail
07-26-2016, 05:42 PM
Heres the jb4 settings
07-27-2016, 04:08 PM
Wierd thing is when i try to delete the codes when the car ia running it almost dies , sometimes it actually does die. Never dis that before when i deleted codes in the past .
Thread Tools |
Display Modes |
