08335ibmw 08335ibmw is offline
Default VERY ROUGH IDLE AND CODES!! =/ - 07-11-2016, 10:00 AM
SO JUST DID A FMIC AND AFTERMERKET ********, EVERYTHING WENT PERFECT... TO PERFECT LOL . SO TOOK IT TO A CAR SHOW ABOUT 100 MILE ROUND TRIP. NO ISSUES BESIDES A FUEL PUMP PLAUSBILTY CODE. DELETED IT , ALL WAS GOOD. WOKE UP THIS MORNING AND GOT ON IT LEAVING A PARKING LOT AND LOSS ALL POWER/BOOST. NOW IM GETING MISFIRES 4 AND 6 CYLINDERS. AND A 29CC SEVERAL MISFIRE. OTHER CODES WERE 29D2 29DO.
ALSO THE FUEL CODE WAS 2AAF. UNFORTUANLLY NO LOGS BECAUSE CAR IS RUNNING REALLY CRAPPY CANT DONT WANT TO DRIVE IT LIKE THIS.
HPFP? INJECTORS? COILS? PLUGS?
PLUGS WERE DONE 4K MILES AGO.
FUEL PUMP WAS DONE IN 2011
IDK ABOUT INJECTORS
PLEASE HELP
Default 07-11-2016, 10:01 AM
ALSO GOT CODES 29F4 AND 2D25 BUT I READ THATS NOTHING REALLY?
Default 07-11-2016, 11:14 AM
For basic fault code diagnostics visiting a mechanic might be more appropriate. If you are trying to sort it out yourself you read the fault codes and search those online for the description and possible causes.
Default 07-11-2016, 11:29 AM
THANKS FOR THE REPLY , BESIDES TAKING IT TO THE DEALER NONE OF THE MECHANICS LOCAL HAVE THE KNOWLEDGE IMHO. I HAVE THE JB4 SO THATS HOW I FOUND THE CODES, LOOKED UP WHAT OTHER PEOPLE SAY THAT HAD THE SAME CODES . BUT CANT FIND A GOOD ANSWER REALLY. ANY WAY TO JUST TEST THE INJECTORS OR HPFP?
Default 07-11-2016, 02:54 PM
Just threw a 30bb code car will not go over 20mph
Default 07-11-2016, 02:55 PM
Any ideas?
Default 07-11-2016, 02:58 PM
Heres what i could get as far as logs , idk if they help
Default 07-12-2016, 08:52 AM
30bb is bad mosfets in the DME. They'll need replaced. Guessing you are an '07
Default 07-12-2016, 01:13 PM
Dealer said dme is fried , just hoping it didnt take anything iut with it . Any one have best solution? They quoted 2140.00 lol
Default 07-12-2016, 02:12 PM
Im a 2008 year idk about build date , any one have the link for the mosfets they know work?
Default 07-13-2016, 05:55 AM
Do a search for replacing the mosfets and save yourself a couple grand.
Default 07-13-2016, 10:37 AM
yea i found post that gave me part numbers but i dont know for sure there the right ones
Jb4 g5 , bms dci, er fmic , active d.ps , bms charge pipe, tial bov -2008 335i
Default 07-16-2016, 11:38 AM
Terry i need help. Took my dme to 2 tv shops they both said mosfets tested good, checked all fuses i could find still nothing. Any ideas?
Default 07-16-2016, 12:14 PM
What you think steve
Default 07-16-2016, 01:21 PM
30bb is typically the mosfets. I'd replace them, it's cheap.
Default 07-16-2016, 01:29 PM
Ok i already bought the parts just got to have them put in , ill keep you posted
mitcho mitcho is offline
Car: 07 335i
Default 07-17-2016, 07:26 AM
Hey I also have a 07 335i, build date on side of door says 05/07 , got the 30BB code and car runs rough and sel on now. several misfires in codes from jb4. Can you tell me where you got the parts from and how much? thanks
Default 07-18-2016, 04:04 PM
Got them from digikey ill find the part nunber
E92Beast E92Beast is offline
Car: 09 E92 335i AT
Default 07-18-2016, 04:08 PM
Go to n54dme.com if you can't fix it urself or find someone
09 E92 335i Msport, fbo+e85 flash, 11.91 @ 119
10 E90 335i, MHD Stage 1
Default 07-18-2016, 04:26 PM
+1 wish i could but im broke even for 499.00 its a good price if your down and dont have time to be down
Car: 07 335i
Default mosfet replacements - 07-21-2016, 04:46 PM
damn i replaced all 6 mosfets and felt ok about the new soldering, damn things were hard to remove off the board, had to push and pull and finally snap. now car wont start at all. any one else have this problem? man if anyone can please call me at 210-215-1972 with info I would appreciate it.
Default 07-22-2016, 06:38 AM
Sounds like the soldering or something with the replacement got botched. If you were having that much difficulty the vias or pads may have been damaged.
Default 07-22-2016, 02:24 PM
So heres a log still got the 2abc code and 3100 , car runs fine just limp mode ..
If any one has some ideas please text me 7725284267
v8killr4u v8killr4u is offline
Car: 335 xi
Default 08-08-2016, 10:20 AM
Did you get this figured out?
