rstihl rstihl is offline
Car: BMW 335i
Default Burnouts in a 135i - 06-30-2016, 04:16 PM
I cant seem to do a standstill burnout in my 2010 135i with mfactory lsd. Traction control all the way off and i rev it up and dump clutch and start to spin a little and as soon as i step on brake it cuts all power. I dont want a line lock. I want to roast my brakes along with my ****in tires!
sshec152's Avatar
sshec152 sshec152 is offline
Car: 07 335i mt
Default 07-01-2016, 10:21 AM
It takes a few tries to get down, but i can do it easily now. I rev it up, dump the clutch and right when you feel it start to spin, just barely touch the brake. You literally have to touch just enough for it to engage.
123ersan 123ersan is offline
Car: 135i n54
Default 07-01-2016, 10:27 AM
Why do you touch the brakes? Doesn't that slow down the wheel and make you gain traction again?
sshec152's Avatar
Car: 07 335i mt
Default 07-01-2016, 04:50 PM
To lock up the front brakes to be able to to a standing burnout. The key is the apply enough pressure to hold the front brakes without locking up the rear brakes and stalling the car.
Enfiftyfore's Avatar
Enfiftyfore Enfiftyfore is offline
Car: 2009 135i
Default 07-01-2016, 09:46 PM
Unless you are running slicks, you only need 5 Seconds of burn out. Even if you are on drag radials, you don't need much. Stop hitting your brakes and stop wasting your tires.
kenjermen's Avatar
kenjermen kenjermen is offline
Car: 2009 BMW 335i
Default 07-01-2016, 10:12 PM
Throw some water under the tires to help them start to spin
2009 BMW 335I with: MHD/Haltech,
precision 6870 turbo, jp Workz header,
Wagner EVO II intercooler,HKS exhaust with cutouts, stage 3 lpfp, wavtech lsd, eospeed intake manifold with fuel return and 60lb injectors
za_1m za_1m is offline
Car: 1M
Default 07-02-2016, 01:27 AM
Why don't you want a line lock?
mikese82 mikese82 is offline
Car: e82 135
Default 07-02-2016, 10:03 AM
Line lock that bitch.
JP Workz 6062 kit stage 3 fuel it mhd/jb4
Car: BMW 335i
Default 07-02-2016, 07:49 PM
I want to roast my ****ing tires for like a minute. And when i touch the brake pedal the gas pedal is dead (like i can push it all the way down engine does not rev.
J.J4ck0wsk1 J.J4ck0wsk1 is offline
Car: N54 335i FBO Meth
Default 07-05-2016, 10:45 AM
Similar issue with my Procede, map 0 and it's fine, but when it's turned on it feels like a secondary traction control is cutting off power and I can't seem to turn it off..
PhilTrill's Avatar
PhilTrill PhilTrill is offline
Car: 135', E46 M3, E36 M3, S13
Default 07-19-2016, 09:57 AM
I have to pull the ABS fuse to get mine to do a brake stand. My buddies auto had no issues until we did the back end flash then he had the same issue as me.
'08 SGM 135i | '12 C63 AMG | '95 S14 | '93 S13 | '90 S13 | '89 S13 | '80 Spitfire
