Wraith07 Wraith07 is offline
Car: 2007 E92 335i AT (05/07 Build Date)
Default How do I find out which DME I have? - 06-04-2016, 07:00 PM
Link to my VIN decoded here
Btw it says my Prod. date is 2007-05-09, so does that mean it was produced in May or September?
keyap keyap is offline
Car: N55 135i
Default 06-05-2016, 04:48 AM
Assuming N54s work the same way as N55s, If you have coding cables and software INPA can do it for you - you can either read the ROM or the zsub. If you read the zsub you'll then need to reference back via the datens This was for a N55 but process should be similar.
I'm sure others will chime in as I'm sure with a N54 they'll be other options too.
FL335's Avatar
FL335 FL335 is offline
Sua Sponte
Car: 13 335is
Default 06-05-2016, 08:16 AM
Go to RealOEM.com and put in the last 7 of your VIN. Navigate to Engine electrical system and then Control units. Voila! And production date would be May.
'13 LMB 335is DCT | MHD/BQ Tuning |
Car: N55 135i
Default 06-05-2016, 08:19 AM
Ignore me - I misread your request and thought you were asking which ROM you had
thistle thistle is offline
Car: E46 M3, D4 S8
Default 06-05-2016, 10:49 AM
I am looking for a flashable N55 UK car. Don't have any sample VIN numbers to check yet, but I have options of 2011 model year 135i and 335i? I have seen a 2010 335i which has TwinPower Turbo emblazoned on the engine cover with registration date of June 2010. That would be a very early N55? Sorry to post in N54 section but the poster above is in the UK and knows his onions I prefer the look of the E92. Does RealOEM show MEVD17.x.y where it gives you x and y so we can tell if flashable or will it just show N55?
Car: N55 135i
Default 06-05-2016, 11:00 AM
I'll PM you as don't want to derail this thread.
WaqasRiyami's Avatar
WaqasRiyami WaqasRiyami is offline
Car: Bmw 535i - 2011
Default 10-27-2017, 08:48 AM
Hello guys sorry to bring this thread back to life, but google searching brought me here
My Vin is : C947492
My Prod. Date 2011-02-15
Car is : F10 535i N55
i only want to know if the DME is locked or it need a one time unlocking
2011 F10 535i N55 PWG 8AT | "Pureboost.de Tune" + MHD Flasher | xHP Stage 3 transmission Tune | N20 3.5bar TMAP Sensor | Pure Stage 2 Turbo | GFB DV+ | Fuel-It Stage 2 LPFP | 93 Octane Fuel | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | Custom Turbo Inlet Pipe | https://i.imgur.com/iR4wm3I.jpg |
