Indo Rider's Avatar
Indo Rider Indo Rider is offline
Car: 135
Default Why is DME BT all over the place? - 04-12-2016, 07:29 AM
I'm usually not looking at DME BT too much, but after switching to MHD backend flash (hybrid E85) I see DME BT jumping around a lot. Is this normal? Can someone explain what's going on? Thanks.
Edit: This is map1, ~E50.
2009 135i 6MT Jet Black, FBO+
Default 04-12-2016, 08:55 AM
Just a function of how the flash mapping works when boost is under the DME's target. It will randomly lower DME BT to actual boost as a diagnostic check of some sort. Since the JB4 ignores DME BT when in back end flash mode its of no consequence.
Taron's Avatar
Taron Taron is offline
Car: 2008 BMW 335XI
Default 05-08-2017, 11:15 PM
Terry small question here. even if jb4 ignores dme bt during boost control when on 4/2 it will affect afrs right? if due to some reason dme bt drops afrs will go higher based on numbers inside the flash.
Default 05-09-2017, 08:17 AM
No, the DME fueling, timing, etc, is mapped on boost, not boost target.
Taron's Avatar
Car: 2008 BMW 335XI
Default 05-10-2017, 11:26 PM
I see. I mixed something. so another question here. I assume as far as you are under 21 psi considering that you do not intend to go over 21.5 psi dme sees real boost right ? in that case it can map to boost itself. but for ST setups who run more than 21 i assume there is scaling and for dem to be able to work with conditions we apply multiplier and dme sees 15 psi for example but in real life its 30(if you have boost level 43 for example). so how in this situation afrs are being calculated. STFT will go crazy ?
thanks in advance
Default 05-12-2017, 05:32 PM
Originally Posted by cnm135i
Terry
Here DME BT is dropped due to 6th gear torque limiter. Looks to me that both AFR, trims and timing are affected because of this?
That is an F series log with a custom back end flash map. Completely different situation. Work with your flash tuner to resolve your specific issue.
Removed your posts since this is an N54 support thread. We had to suspend your last account for chiming in to unrelated threads spreading incorrect information. If it continues we'll have to suspend your new one as well.
Default 05-12-2017, 05:34 PM
thanks in advance
When factory observed boost is on DME BT then DME BT straightens out. Only when its below target does the DME "hunt" DME BT down to actual boost as part of an internal and completely harmless process.
