So I wanted to start a thread to discuss what advantages we could have running just DI. Only because I do believe if we all want it it could possibly happen.
I'm also going to have to supplement my fuel system this spring and at the very least want to learn a bit about the safety, so dual purpose.
Safety/cut off- So as I understand it there's two control schemes for PI right now. AIC6 by itself and AIC6 controlled by JB4. Using AIC6 if the DME cuts fuel I'd assume the only reference's AIC6 has is boost reading and spark timing. So it would have to wait until it recognizes boost falling then react to that and cut PI. I'm not sure how quickly it'll pick up on the loss of spark, maybe thats faster and it uses that? Wouldn't we end up with several combustion events where the motor is running on just PI.. So super lean? JB4 is great and maybe Terry can answer but I doubt throwing that in the mix is gonna make it react that much faster.
Power- Would we make significantly more power using just DI? Obviously the atomization would be a lot better. I know that's good for efficiency and a better burn but at high load levels would there be a difference in power output? It would be more resilient to knock at least right? Letting us feel comfortable with tossing some more timing perhaps? Or even just helping to eliminate timing drops.
Head Flow- Our intake tract was obviously designed for just air, not a fuel air mix. Therefore our runners are quite small. Not an issue I'll run into, more for you big single guys but pretty soon won't you guys run out of head flow. N54 is at what ~860whp max currently. At what point do these runners just run out of flow? I'm sure there's math that can be done but I'd imagine looking at them we have to be close at this point. I'm sure you could port the head to expand the working range some but at the loss of low end drivability and possibly throwing the intake cam optimization out of wack.. Which can't be fixed because aftermarket cams that play nice with VANOS don't seem to exist. Just seems like the most complicated path to be going down.
What we know about our fuel system.
Injectors- Our injectors are huge to allow the motor to run on just low pressure fuel (72 psi) in case of a HPFP failure. Theoretically our injectors should be good for 1000whp easily. We also know that raising injection pressure is NOT recommended, a Continental engineer made it clear he wouldn't raise the pressure due to leaking concerns. Injection window is the likely cure here and injectors shouldn't be an issue.
LPFP- there's obviously plenty of solutions for this. Including Vargas's custom 1200hp system. Non issue.
HPFP- This is where our problems lye. Our HPFP are mechanically driven and run out of breath fairly quickly. They also historically aren't that reliable. It's important to realize how they're not reliable. Our pumps consist of a mechanical bellow pump directly driven by the Engine. This is at set ratio compared to the motor and output rises with engine RPM. Fuel flow is therefore controlled by an electrical valve. The fuel control valve (FCV), THIS is what fails on our HPFP NOT the mechanical element.
Vargas turbo has come up with a possible solution. The solution is to drive the pump at a faster ratio compared to the Engine, this is done by moving the driving force from an internal chain in the engine to on the accessory belt. This shouldn't play into the HPFP failures we've seen as once again the problem has been with the electrical control valve which is uneffected by this change. Pump weaf has not been an issue stock and Tony says hes tested it for over a year on the same pump. I know not everyone loves Vargas but this approach IMO might be the best one.
This is good for 550whp on E85 or less. (Ethanol seems a requirement at this point) The other solution would be leaving the OEM pump alone and adding a second pump in Vargas shotgun fashion. I believe this would be our ultimate solution. Theoretically should be good for ~900whp. Enough that anyone wanting more then that could use port injection. (Remember at 900whp our intake would only be carrying the air, not the air plus about 350whp of fuel, allowing margin for PI) these real OG guys looking for that power could deal with the associated sketchyness that we deal with now, thats life at the top.
Now the FCV system is complicated so running anything other then OEM pumps doesn't look likely for us. Even running two OEM pumps seems to trip up the DME. Jyamona thinks he can work on that though.. And that's something I'd love to see, so what do you guys think?
Personally the possible lag in control of the PI erks me and I dont really like it.
https://youtu.be/cDGlN6mluGA
